Introducción
Replacing a broken display assembly gives you a new LCD, front glass, display enclosure, iSight camera, and new AirPort antennas.
Qué necesitas
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the camera cable connector straight out of its socket on the logic board.
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
Remove the antenna/camera cable retainer from the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
37 personas más completaron esta guía.
2 comentarios
Hello there
Half a cup of water fell on my MacBook Pro and I tried to quickly dry it out of the water, and I turned on the laptop after more than four hours, but the screen did not work. There are graphics on the screen, but the lighting does not work. Today I changed the screen, but the problem still persists. The lighting of the keys is on, but the lighting of the screen does not work. So please could you help me?
