Saltar al contenido principal
MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement
Qué necesitas
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement, Access Door: paso 1, imagen 1 de 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement, Access Door: paso 1, imagen 2 de 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement: paso 2, imagen 1 de 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement, Battery: paso 3, imagen 1 de 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive to the hard drive bracket.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Lift the hard drive by its pull tab enough to grab and remove the retaining bracket.
    • Lift the hard drive out of the upper case, minding the cable attaching it to the computer.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the hard drive from its cable by pulling the cable connector straight away from the drive.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Remove two T6 Torx screws from each side of the hard drive (four screws total).
    • You'll need to transfer these screws to your new hard drive if you're changing drives.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Conclusión
333 personas más completaron esta guía.
7 comentarios
At step 7, the side screws are very tight. Both T6 Torx and 1.5 Hex keys dont work for me. I fear the screws could get damaged if i try more. How do i unscrew them?
svelcme - Contestar
What was your solution to removing the screws? I am having the same isse.
Kevin Gordon -
Perfect instructions. I am now running a Crucial SSD drive and the improvement is amazing. Thanks.
Carlos - Contestar
Hello
Sandisk X400 SSD proposed for this macbook works in 3gb/s?
There is a known limitation of nvidia chipset with ssd's who appear to work as sataI instead of sataii.
Thank you
George Konstantakis - Contestar
Any news regarding this?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 112
Todo El Tiempo: 249,115
