Introducción
Has the right side of your MacBook Pro gone mute? Use this guide to replace the subwoofer & right speaker assembly.
Qué necesitas
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Disconnect the camera cable connector from its socket on the logic board.
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
Peel the hard drive cable up from the channel within the subwoofer and right speaker.
18 personas más completaron esta guía.
