Introducción
Provides power to the machine and includes all ports on the left side of the machine.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Before beginning, I found some small plastic bags and labeled each of the with the location the screws would come from once removed and the appropriate step number. Once the screws were removed I placed them in the labeled bags and did not have to worry about mixing screws up. Also, provided a good way to insure that no steps were skipped in the reverse process
rpbetancourt - Contestar
If you don't have any plastic bags, you can always print out the photos in black and white as you go, and then tape the screws on to the print outs over the circles that denote the screw positions in the photos. This method helps get every single screw back in it's exact location, even months after a tear down. ;o)
Adam - Contestar
Quote from Adam:
Thank you very much!
Evgeniy - Contestar
When I did this, I used a empty egg carton to store my screws. I wrote the steps where I removed screens in Sharpie on the bottom of the "egg cup" and then dropped the screws in as I went. Then I just worked backwards to put it all back together.
mark93 - Contestar
Quote from rpbetancourt:
I Generally just use a piece of paper with a rough sketch of the system and locations of the screws with prestik.
Tarn Alcock - Contestar
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
  • Make sure to record which sets of screws came from where. This will help when re-assembling.
Agregar Comentario
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Agregar Comentario
Remove the two Phillips screws in the battery compartment near the latch.
  • Remove the two Phillips screws in the battery compartment near the latch.
Getting these screws in and out is difficult because most screwdrivers are longer then the battery compartment is deep and so will be slightly off plumb. When you go to re-assemble the computer, getting these screws to seat is one of the hardest parts of the re-assembly. It's very important to be gentle and not to strip the threads.The screw should tighten and come to a stop after 3-4 turns. If you turn 6 or more turns and don't feel it grab, then back off and try again, making sure that everything is in alignment.It might be easier to start with the left screw, because it is further away from the latch mechanism.
dalphotography - Contestar
Remove the following 6 screws:
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
A T6 worked but was too small. A T7 was better.
Nelson R Pardee - Contestar
Remove the four Phillips screws on the port side of the computer.
  • Remove the four Phillips screws on the port side of the computer.
Be careful when reassembling your laptop -- do not put the screw into the DVI port! It will not come out.
Scott Rose - Contestar
by Scott Rose Jan 4 @ 11:12 PM
To keep this from possibly happening, I placed 2 pieces of tape over the DVI connector pin holes.
Be careful in step 4, these two screws are shorter than the four screws in step 6, dont mix them up!
brendantully1 - Contestar
If you still have the DVI to VGA adapter that came with the computer plug it in to the plug and screw it tight, that way you will not put one of the screws into the holes.
netdude21 - Contestar
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Agregar Comentario
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Agregar Comentario
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
  • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
there are 2 push buttons inside the harddrive bay which release the front of the upper case.
mforgie - Contestar
this is an annoyingly difficult step. it is VERY hard to get the front part off without bending the unit improperly. Would be great to know where the two "push buttons" are.
lessig - Contestar
On my MacBook, there were no pushbuttons. Rather, two mini phillips screws were holding the case on inside the battery bay. The two screws are under two ball-bearing-like nubs that help hold the battery in the bay.
khank - Contestar
Quote from khank:
I just realized these were the screws mentioned in Step 4, which I missed originally. Did you miss step 4 too?
khank - Contestar
I discovered that I didn't need to take the case off completely. I just propped it up with a small screwdriver and was able to remove the airport card and replace it with a new one fairly easily.
schemedream - Contestar
That's not so difficult step. you shoul know , that front edge of upper case holding only on 5 plastic "locks" 4 in front edge upon the superdrive, 5-th near the "sleep light, open laptop button"
just lift up the rear edges of upper case to 35-40 degrees
Hofmann78rus - Contestar
[I d just say carefule on the prising open - these are fragile screw tab fixings joined to the uppercase. - Patience and gentle pressure and all works fine .
daithid - Contestar
Getting the top case off, especially right above the optical drive slot was a @#$%^. !^$%. Was finally able to work it loose by twisting in the budger. Be careful.
Archhawk - Contestar
the two push pins are in the battery area behind the front of the open button
mykeylynx - Contestar
Quote from Archhawk:
I agree! It was really very difficult just ROCKING the front panel. NOT done! Do not pry it from the front of the unit, as the soft metal edge gets scratched! I turned the unit upside down and slowly pried the keyboard apart left-to-right from INSIDE the Battery Bay, slipping a plastic pen to keep it apart. When I finally looked at what was holding it down, it was these 5 grey&black plastic SNAP slots, and 4 of them were behind the DVD slot.
http://www.facebook.com/photo.php?pid=40...
Mario da Silva - Contestar
I found I had to push with a little force from underneath the battery compartment where the touch pad is located to free the bottom edge of the case. The case came away with two loud snaps. At first I thought I'd broken something, but then it appeared that it was just the plastic above the slot loading super drive that was held in very tightly and needed some encouragement.
Joshua May - Contestar
There are several clips along the front of the case in front of trackpad and above the optical drive slot. These need to be gently levered open (eg using an old credit card), and clipped closed on reassembly. Start at the left hand side. Take care not to bend the aluminum top. When reassembling, check the top panel for kinks/bends and straighten by hand before reassembly.
cheongi - Contestar
The way I did it was to lift the back to about 45% (the ribbon cable is long enough) and then used the spudger to force the 4 snap tabs in front of the optical drive to separate, working from the right edge towards the middle (they will 'pop'), ending with the last tab to the left of the sleep light.
Hilal Malawi - Contestar
After reading all the step 9 comments I was prepared for it to be very difficult. The two bendable tabs on the left front of the case were no bigger than 1/4 inch wide each and caused no trouble taking it off or putting it back on. Lifting the cover off happened before I knew it. I was carefully lifting the cover from side to side and 'poof' it was off and the yellow ribbon attaching between the case and the keyboard was so old and brittle it parted ways without my permission so that took care of step 10 right there but no problem.
Being prepared, reading the guide, printing the guide, taping each screw to the right place on the guide made it all easy. I'm amazed it went so smooth on the first run-through. Thanks iFixit!
Sally - Contestar
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
not necessary. just attach a string around both the screen and the keyboard. it will stay in a steady position..
-urdus.
urdus - Contestar
I found that the ribbon connecting the top part of the case to the logic board wasn't long enough and the connector did have to be disconnected.
Joshua May -
Quote from urdus:
-urdus.
Excellent tip! Thanks, this allowed me to skip steps 10 and 11 (any unnecessary tinkering with the logic board is recommended).
Disconnect the iSight, inverter, and left fan cables from the logic board.
  • Disconnect the iSight, inverter, and left fan cables from the logic board.
My MacBook Pro Model (15'', 2.16GHz Core 2 Duo from 2006) had slightly different connectors. I had ordered a fan replacement as seen above (with the white connector), but my old fan had a smaller black one that snaps onto the logic board. Since the rest of the fan unit was exactly the same, I de-soldered the 4-wire cable from my old fan, and used it to replace the connector cable on the new one. The color coding is slightly different, but if you keep the connector wires in the same order, everything works fine.
Armin - Contestar
Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
  • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
  • Slide the left ambient light sensor cable to the left and out of its connector.
While the other cables end in a plug, the end of the light sensor cable will appear bare after you remove it. In the down position, the brown plastic flap very gently clamps the end of the cable in place.
PaKo - Contestar
This is the most difficult step of the whole procedure. You really have to lift up the brown flap from the left side.
Ute Schueller - Contestar
That step 12 gave me a hard attack. I had not read properly and I thought that the cable for the light ambient was just coming off like the other three connectors to disconnect. When I was left with the bare cable without the connector at the end, I #!?*@*! a bit but then realized that it was a lift tab that which, when pushed down, put the pressure of on the cable to stay in place. So all was fine, I was able to replace the left fan (had to replace the right fan about a year ago). The ambient light cable was fine as the keyboard glowed properly.
viaughislain - Contestar
Peel up the left ambient light sensor cable from above the left fan.
  • Peel up the left ambient light sensor cable from above the left fan.
Agregar Comentario
Peel up the iSight and inverter cables from above the left fan, removing tape as necessary.
  • Peel up the iSight and inverter cables from above the left fan, removing tape as necessary.
Agregar Comentario
Remove the following 3 screws:
  • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
Note here that the the Torx screw near the left speaker assembly passes through the eyelet for the speaker first then through the eyeleft for the cooling fan. When putting in a replacement fan ensure that the fan eyelet is underneath the speaker eyelet.
cgollner - Contestar
Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
  • Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
The tape you peel up may no longer be sticky enough when putting it down on a replacement fan. I used some electrical tape cut to size to redo the seal.
The ring at the top which holds the top screw appeared to be underneath the same ring for the speaker and this made it really tricky to remove the fan.
You really have to get the right angle. Persevere as it will come away with some gentle encouragement.
Be sure to transfer the black tape to the new unit or else replace it with electrical tape.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Agregar Comentario
Disconnect the two antenna cables attached to the Airport Extreme card.
  • Disconnect the two antenna cables attached to the Airport Extreme card.
  • The white antenna cable connects to the left side of the Airport Extreme card.
Agregar Comentario
Remove the single silver Phillips screw located just above the Airport Extreme card.
  • Remove the single silver Phillips screw located just above the Airport Extreme card.
  • Lift the small silver metal retaining bracket up and out of the computer.
Agregar Comentario
Peel back the orange tape on the right side of the Airport Extreme card.
  • Peel back the orange tape on the right side of the Airport Extreme card.
  • Lift the Airport Extreme card up and slide it out of its connector.
Agregar Comentario
Peel up the orange hard drive cable from above the ExpressCard cage.
  • Peel up the orange hard drive cable from above the ExpressCard cage.
Agregar Comentario
Disconnect the speaker cable from the corner of the left I/O board.
  • Disconnect the speaker cable from the corner of the left I/O board.
Agregar Comentario
Remove the single black T6 Torx screw securing the left speaker.
  • Remove the single black T6 Torx screw securing the left speaker.
Agregar Comentario
Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
  • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
Agregar Comentario
Disconnect the large multi-colored power cable from the left I/O board.
  • Disconnect the large multi-colored power cable from the left I/O board.
Agregar Comentario
Remove the following 5 screws/standoffs:
  • Remove the following 5 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
Agregar Comentario
Lift up the right side of the left I/O board and slide it out of the computer.
  • Lift up the right side of the left I/O board and slide it out of the computer.
Agregar Comentario
Remove the following 4 screws:
  • Remove the following 4 screws:
    • Three 1.2 mm silver Phillips with large heads.
    • One 3.2 mm black Phillips on the left side.
Agregar Comentario
Lift the left I/O board off the ExpressCard cage.
  • Lift the left I/O board off the ExpressCard cage.
Agregar Comentario
Disconnect the short left I/O board cable.
  • Disconnect the short left I/O board cable.
  • Left I/O board remains.
Agregar Comentario
Conclusión
19 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Just curious what the short cable's purpose is? I have a Macbook this model and the battery is not charging. Before I go down the path of changing out the whole board is it worth replacing just this cable?
adamstafford - Contestar
What are the symptoms of needing to replace this board?
jeff7 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 26
Todo El Tiempo: 33,419
