Introducción
Charges battery and connects battery to logic board.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Before beginning, I found some small plastic bags and labeled each of the with the location the screws would come from once removed and the appropriate step number. Once the screws were removed I placed them in the labeled bags and did not have to worry about mixing screws up. Also, provided a good way to insure that no steps were skipped in the reverse process
rpbetancourt - Contestar
If you don't have any plastic bags, you can always print out the photos in black and white as you go, and then tape the screws on to the print outs over the circles that denote the screw positions in the photos. This method helps get every single screw back in it's exact location, even months after a tear down. ;o)
Adam - Contestar
Quote from Adam:
Thank you very much!
Evgeniy - Contestar
When I did this, I used a empty egg carton to store my screws. I wrote the steps where I removed screens in Sharpie on the bottom of the "egg cup" and then dropped the screws in as I went. Then I just worked backwards to put it all back together.
mark93 - Contestar
Quote from rpbetancourt:
I Generally just use a piece of paper with a rough sketch of the system and locations of the screws with prestik.
Tarn Alcock - Contestar
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
  • Make sure to record which sets of screws came from where. This will help when re-assembling.
Agregar Comentario
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Agregar Comentario
Remove the two Phillips screws in the battery compartment near the latch.
  • Remove the two Phillips screws in the battery compartment near the latch.
Getting these screws in and out is difficult because most screwdrivers are longer then the battery compartment is deep and so will be slightly off plumb. When you go to re-assemble the computer, getting these screws to seat is one of the hardest parts of the re-assembly. It's very important to be gentle and not to strip the threads.The screw should tighten and come to a stop after 3-4 turns. If you turn 6 or more turns and don't feel it grab, then back off and try again, making sure that everything is in alignment.It might be easier to start with the left screw, because it is further away from the latch mechanism.
dalphotography - Contestar
Remove the following 6 screws:
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
A T6 worked but was too small. A T7 was better.
Nelson R Pardee - Contestar
Remove the four Phillips screws on the port side of the computer.
  • Remove the four Phillips screws on the port side of the computer.
Be careful when reassembling your laptop -- do not put the screw into the DVI port! It will not come out.
Scott Rose - Contestar
by Scott Rose Jan 4 @ 11:12 PM
To keep this from possibly happening, I placed 2 pieces of tape over the DVI connector pin holes.
Be careful in step 4, these two screws are shorter than the four screws in step 6, dont mix them up!
brendantully1 - Contestar
If you still have the DVI to VGA adapter that came with the computer plug it in to the plug and screw it tight, that way you will not put one of the screws into the holes.
netdude21 - Contestar
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
Agregar Comentario
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
Agregar Comentario
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
  • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
there are 2 push buttons inside the harddrive bay which release the front of the upper case.
mforgie - Contestar
this is an annoyingly difficult step. it is VERY hard to get the front part off without bending the unit improperly. Would be great to know where the two "push buttons" are.
lessig - Contestar
On my MacBook, there were no pushbuttons. Rather, two mini phillips screws were holding the case on inside the battery bay. The two screws are under two ball-bearing-like nubs that help hold the battery in the bay.
khank - Contestar
Quote from khank:
I just realized these were the screws mentioned in Step 4, which I missed originally. Did you miss step 4 too?
khank - Contestar
I discovered that I didn't need to take the case off completely. I just propped it up with a small screwdriver and was able to remove the airport card and replace it with a new one fairly easily.
schemedream - Contestar
That's not so difficult step. you shoul know , that front edge of upper case holding only on 5 plastic "locks" 4 in front edge upon the superdrive, 5-th near the "sleep light, open laptop button"
just lift up the rear edges of upper case to 35-40 degrees
Hofmann78rus - Contestar
[I d just say carefule on the prising open - these are fragile screw tab fixings joined to the uppercase. - Patience and gentle pressure and all works fine .
daithid - Contestar
Getting the top case off, especially right above the optical drive slot was a @#$%^. !^$%. Was finally able to work it loose by twisting in the budger. Be careful.
Archhawk - Contestar
the two push pins are in the battery area behind the front of the open button
mykeylynx - Contestar
Quote from Archhawk:
I agree! It was really very difficult just ROCKING the front panel. NOT done! Do not pry it from the front of the unit, as the soft metal edge gets scratched! I turned the unit upside down and slowly pried the keyboard apart left-to-right from INSIDE the Battery Bay, slipping a plastic pen to keep it apart. When I finally looked at what was holding it down, it was these 5 grey&black plastic SNAP slots, and 4 of them were behind the DVD slot.
http://www.facebook.com/photo.php?pid=40...
Mario da Silva - Contestar
I found I had to push with a little force from underneath the battery compartment where the touch pad is located to free the bottom edge of the case. The case came away with two loud snaps. At first I thought I'd broken something, but then it appeared that it was just the plastic above the slot loading super drive that was held in very tightly and needed some encouragement.
Joshua May - Contestar
There are several clips along the front of the case in front of trackpad and above the optical drive slot. These need to be gently levered open (eg using an old credit card), and clipped closed on reassembly. Start at the left hand side. Take care not to bend the aluminum top. When reassembling, check the top panel for kinks/bends and straighten by hand before reassembly.
cheongi - Contestar
The way I did it was to lift the back to about 45% (the ribbon cable is long enough) and then used the spudger to force the 4 snap tabs in front of the optical drive to separate, working from the right edge towards the middle (they will 'pop'), ending with the last tab to the left of the sleep light.
Hilal Malawi - Contestar
After reading all the step 9 comments I was prepared for it to be very difficult. The two bendable tabs on the left front of the case were no bigger than 1/4 inch wide each and caused no trouble taking it off or putting it back on. Lifting the cover off happened before I knew it. I was carefully lifting the cover from side to side and 'poof' it was off and the yellow ribbon attaching between the case and the keyboard was so old and brittle it parted ways without my permission so that took care of step 10 right there but no problem.
Being prepared, reading the guide, printing the guide, taping each screw to the right place on the guide made it all easy. I'm amazed it went so smooth on the first run-through. Thanks iFixit!
Sally - Contestar
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
not necessary. just attach a string around both the screen and the keyboard. it will stay in a steady position..
-urdus.
urdus - Contestar
I found that the ribbon connecting the top part of the case to the logic board wasn't long enough and the connector did have to be disconnected.
Joshua May -
Quote from urdus:
-urdus.
Excellent tip! Thanks, this allowed me to skip steps 10 and 11 (any unnecessary tinkering with the logic board is recommended).
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the following 3 screws:
  • Remove the following 3 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.8 mm black Phillips screw at the top right corner of the drive.
    • The 4.8mm screw may be a T6 Torx
On my model (core duo 1.8 ghz Macbook Pro) that "One 4.8mm black Phillips screw at the top right corner of the drive" is a silver Torx T6 screw.
holmesworcester - Contestar
Mine was a silver T6 Torx also.
Melissa Godsey -
My machine had a grey Torx here.
dave -
There was one extra silver Torx T6 screw, at the top left of the drive, immediately left of the ribbon cable connection, that I had to remove in order to extract the Optical drive. It is visible in the picture for Step 12.
pensivemonk - Contestar
On my MBP 15.4" santa rosa (July 2007), the bottom left 3.3mm screw is smaller than this and doesn't fit a PH000 screw driver.
Greg K - Contestar
On my A1150, the black screw wasn't- it is a silver Torx 6
stevesontheroad - Contestar
Take special care with the small Pillips screw to the left of the drive. The strong-ish magnet of the lid catch is likely to snatch the screw fron your driver and allow it to fall into the space below and it is a complete pain to fish out! Ask me how I know!
dave - Contestar
Lift the optical drive up and out of the computer.
  • Lift the optical drive up and out of the computer.
Agregar Comentario
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Agregar Comentario
Disconnect the eight indicated connectors from the logic board, removing tape as necessary.
  • Disconnect the eight indicated connectors from the logic board, removing tape as necessary.
I wish there was some tip or picture how to remove the tiny ones. I already broke the left als
Shann ell - Contestar
Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
  • Use a spudger to flip up the brown plastic flap securing the left ambient light sensor cable to the logic board.
  • Slide the left ambient light sensor cable to the left and out of its connector.
Agregar Comentario
Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
  • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
Agregar Comentario
Remove the single silver T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Remove the single silver T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Lift the clear plastic shield off the right ambient light sensor.
Agregar Comentario
Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
Agregar Comentario
Remove the following 16 screws, moving cables as necessary:
  • Remove the following 16 screws, moving cables as necessary:
    • One 4.4 mm black Phillips screw to the right of the RAM slot.
    • Nine 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
When reassembling, make sure all cables are above the logic board before you start putting the screws back in, especially the battery to logic board connector.
Steve S - Contestar
And, even MORE especially, the heat sensor cable that attaches to the tiny white connector near the middle-left of the logic board. If you don't you have to take everything apart again when you get back to the step where you reattach all the cables.
Steve S - Contestar
Where is the photo please
zeplin76 - Contestar
The photo for Step 20 seems to be missing.
Jason Blanzy - Contestar
Move the display data cable to the right, removing tape as necessary.
  • Move the display data cable to the right, removing tape as necessary.
  • Peel up and remove the orange foil shield near the right speaker.
Agregar Comentario
Rotate the speaker clockwise approximately 30 degrees until it comes free from the logic board.
  • Rotate the speaker clockwise approximately 30 degrees until it comes free from the logic board.
Agregar Comentario
Peel up the gray and black speaker wires from the top of the logic board, removing tape as necessary.
  • Peel up the gray and black speaker wires from the top of the logic board, removing tape as necessary.
Agregar Comentario
Peel up the iSight and inverter board cables from above the left fan.
  • Peel up the iSight and inverter board cables from above the left fan.
  • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
  • Place the fan above the Airport card. It is not necessary to entirely remove the fan from the computer.
When reassembling, the left fan goes under the black tab on the left speaker.
Steve S - Contestar
I would recommend actually removing the fan as it is just another flip connector like the other side of the ribbon cable. This way it is less likely to damage the ribbon and leaves the fan out of the way.
Sebastian Malton - Contestar
The fan was actually stuck to the cooling fins of the heat-sink. I had to peel up the black tape and VERY CAREFULLY pry the two apart.
dave - Contestar
Take GREAT care with the left ambient light sensor cable it is very delicately attached!
dave - Contestar
It may be helpful to hold the heat sink in place while removing the right fan.
  • It may be helpful to hold the heat sink in place while removing the right fan.
  • Lift the right fan up while carefully peeling up the tape which secures the fan to the heat sink.
  • Remove the right fan from the computer.
Step 25: now is a good time to retrieve and put somewhere safe the right ambient light-sensor cover.
edgroupinc - Contestar
Lift up the left side of the logic board and disconnect the multi-colored power cable from the bottom of the board.
  • Lift up the left side of the logic board and disconnect the multi-colored power cable from the bottom of the board.
Agregar Comentario
The logic board is still attached to the computer by one more cable, so don't lift the logic board too far out of the computer yet.
  • The logic board is still attached to the computer by one more cable, so don't lift the logic board too far out of the computer yet.
  • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
  • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound from the chips on the back of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
Agregar Comentario
Disconnect the right thermal sensor cable from the bottom of the logic board near the DVI port.
  • Disconnect the right thermal sensor cable from the bottom of the logic board near the DVI port.
THIS little component gave me the most aggravation of the whole job! It's too small to get even needle-nosed pliers on, so I ended up spearing it with a dentist's pick and prying it out.
dave - Contestar
Remove the two silver T6 Torx screws securing the battery connector to the lower case.
  • Remove the two silver T6 Torx screws securing the battery connector to the lower case.
Agregar Comentario
Disconnect the large multi-colored battery connector cable from the left I/O board.
  • Disconnect the large multi-colored battery connector cable from the left I/O board.
Agregar Comentario
Peel up the orange tape securing the battery connector to the lower case, and lift the battery connector out of the computer.
  • Peel up the orange tape securing the battery connector to the lower case, and lift the battery connector out of the computer.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 17
Todo El Tiempo: 13,138
