Introducción
Ahorra dinero reemplazando solo la pantalla LCD en lugar de todo el conjunto de la pantalla.
Usa tus dedos para empujar ambas lengüetas de liberación de la batería lejos de la batería, y levanta la batería de la computadora. Usa tus dedos para empujar ambas lengüetas de liberación de la batería lejos de la batería, y levanta la batería de la computadora. Usa tus dedos para empujar ambas lengüetas de liberación de la batería lejos de la batería, y levanta la batería de la computadora.
  • Usa tus dedos para empujar ambas lengüetas de liberación de la batería lejos de la batería, y levanta la batería de la computadora.
Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
ColmillodeChile - Contestar
Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
Danny Lim -
Citation de ColmillodeChile :
What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
Adrian - Contestar
No, that's nonsense
max damage -
Citation de Adrianthomaspre :
Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
Adrian - Contestar
The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
Doug - Contestar
Citation de Doug :
I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
(Remplacement de la RAM des MacBook Pro 15" Core 2 Duo, modèles A1226 et A1260)
Don - Contestar
I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
Citation de Don :
Doug - Contestar
Retira los tres tornillos idénticos PH000 Phillips de 2 mm de la puerta de la memoria. Levanta la puerta de la memoria lo suficiente como para agarrarla y deslizarla hacia ti, separándola de la carcasa.
  • Retira los tres tornillos idénticos PH000 Phillips de 2 mm de la puerta de la memoria.
  • Levanta la puerta de la memoria lo suficiente como para agarrarla y deslizarla hacia ti, separándola de la carcasa.
These screws are different from the rest, they should be kept separate from the others.
Maarten Van Coile - Contestar
Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
dlyons - Contestar
Retira los dos tornillos Phillips de 2,8 mm en el compartimento de la batería cerca del pestillo.
  • Retira los dos tornillos Phillips de 2,8 mm en el compartimento de la batería cerca del pestillo.
Keep these two Philips screws separate. The screws are approximately 0.5mm shorter in length. When using one or two of the other longer screws in the battery compartment when reassembling, the lid will not open because the screw(s) do yam the lid button.
Peter van Nes - Contestar
I had a logic board replaced by Apple (bad nVidia GPU), and believe it or not the Apple tech mixed up the screws. My latch did not work as good until I discovered and swapped the misplaced screws.
madmaxmedia - Contestar
I removed the memory here as you would normally if you were changing it.
Mike Matthias - Contestar
Retira los siguientes 6 tornillos:
  • Retira los siguientes 6 tornillos:
    • Dos tornillos Torx T6 de 10 mm a cada lado de la ranura RAM.
    • Cuatro tornillos Phillips de 14.5 mm a lo largo de la bisagra.
Agregar Comentario
Retira los cuatro Phillips PH00 de 3.2 mm en el lado de los puertos de la computadora.
  • Retira los cuatro Phillips PH00 de 3.2 mm en el lado de los puertos de la computadora.
If you are using a muffin pan to keep removed parts separate (a method I recommend highly), note that Steps 5, 6, and 7 involve removing the same size screw—and thus you can put them all in the same pile. This is unlike just about every other part you will remove during this procedure.
Matt McCaffrey - Contestar
Using shot glasses!
peterbcpa -
If you are a mac newbie like me take care when you reassemble not to insert a screw in the DVI display port screw holes (shame). I cannot manage to get it out anymore.
tai manu - Contestar
I did the same thing once, and eventually got it out. Try tweezers, a screwdriver, magnets, holding the MBP on its side so gravity is working with you, etc. Eventually the little bugger will come out, you just have to keep working at it.
madmaxmedia -
It would be a good idea to put some sticky tape on those two DVI display port holes, so that you never make the mistake to insert (when reassemble) any of the screws!
genik - Contestar
RE: Misplaced Screws in the DVI port, I was upgrading an early 2008 MacBook Pro with an SSD to get some more life out it, and sure enough, misplaced one of these small screws into the DVI port upon reassembly. Screwdrivers, shaking, gravity... nothing worked. UNTIL I went to my dad's house and his super-comprehensive workbench, where he found a small, high-pull magnet and the little bugger flew right out. Refrigerator magnets won't cut it, you will need a more powerful magnet, such as these: http://www.kjmagnetics.com/products.asp?...
Hope this helps someone... it was an easy solution to a frustrating problem
John Lee - Contestar
Gira la computadora 90 grados y retira los dos tornillos Phillips de 3,2 mm de la parte posterior de la computadora.
  • Gira la computadora 90 grados y retira los dos tornillos Phillips de 3,2 mm de la parte posterior de la computadora.
Agregar Comentario
Gira la computadora 90 grados nuevamente y retira los cuatro tornillos Phillips de 3,2 mm del lateral de la computadora.
  • Gira la computadora 90 grados nuevamente y retira los cuatro tornillos Phillips de 3,2 mm del lateral de la computadora.
Agregar Comentario
No quites la cubierta superior rápidamente. La carcasa está unida a la placa lógica mediante un cable plano. Levanta la parte trasera de la carcasa y mueve los dedos a lo largo de los lados, liberando la carcasa sobre la marcha. Una vez que hayas liberado los lados, es posible que debas mover la caja hacia arriba y hacia abajo para liberar el frontal de la carcasa superior. Hay cuatro clips de plástico encima de la ranura del DVD, y otro arriba y a la izquierda del sensor IR. Estos clips pueden ser muy difíciles de desenganchar sin hacer palanca. También pueden ser difíciles de volver a conectar durante el reensamblaje.
  • No quites la cubierta superior rápidamente. La carcasa está unida a la placa lógica mediante un cable plano.
  • Levanta la parte trasera de la carcasa y mueve los dedos a lo largo de los lados, liberando la carcasa sobre la marcha. Una vez que hayas liberado los lados, es posible que debas mover la caja hacia arriba y hacia abajo para liberar el frontal de la carcasa superior.
  • Hay cuatro clips de plástico encima de la ranura del DVD, y otro arriba y a la izquierda del sensor IR. Estos clips pueden ser muy difíciles de desenganchar sin hacer palanca. También pueden ser difíciles de volver a conectar durante el reensamblaje.
  • Consejo de reensamblado: presiona firmemente la punta de la carcasa superior sobre la ubicación de cada clip hasta que oigas un chasquido para volver a colocarlos en sus ranuras.
  • Consejo de reensamblado: Los dos clips centrales del DVD rara vez se ajustarán de nuevo correctamente sin ayuda, y la presión hacia abajo simplemente deformará el marco de la ranura del DVD. Apoya el marco insertando un spudger en la ranura del DVD directamente bajo el clip hasta que se ajuste, luego presiona hasta que oigas el chasquido.
The clips above the DVD slot (below the deck palm rest) are an absolute bear. They're hard to get released, and even harder to get back locked when you reassemble. (I've read to tilt the deck toward you when reassembling, inserting the front edge first, and press about an inch back from the edge to get all the front clips locked first before lowering the rest (back) of the deck.) No success for me yet, best of luck.
sonofray - Contestar
I thought these two videos did an excellent job of showing the technique of removing and replacing the drive.
MacBook Pro/PowerBook Keyboard Replacement (Part 1 of 3):
http://www.youtube.com/watch?v=jUonF9OSv...
MacBook Pro/PowerBook Keyboard Replacement (Part 3 of 3):
http://www.youtube.com/watch?v=JWeFXWXpp...
After watching that, I had the keyboard replaced in 2 minutes.
Chris -
the technique you describe of putting the front down first, is exactly what I did and it worked well
dillonsavard -
Those clips on the front edge are very challenging. I have a set of nylon pry tools that are for taking apart car dashboards without scratching the vinyl or plastic. I was able to get a long one in from the side and twist it which freed the clips without damaging the plastic on the upper case or the aluminum on the lower case.
Putting it back together presented another challenge. When I first re-assembled it I think I pushed too hard over the DVD slot and accidentally bent the metal down. I was able to bend it back up using a thicker part of those same nylon pry tools, and then i was able to get it snapped back down successfully. Had I known this would happen, I would have just put the nylon tool in the slot to reinforce the metal as I was snapping the case back down.
Nick - Contestar
As everyone has said, the front clips by the DVD can be really tight. Use the spudger to pry the top and bottom halves apart. Slow work it in from one side to separate the top and bottom.
When reassembling the case, work the front clips by the DVD drive back in first. Once you slide them back in, the rest of the case fits easily.
Ted Wise - Contestar
i've used an old atm card, it works fine.
rotarypot - Contestar
I had a lot of trouble with getting those clips to lock in place again when reassembling. The way I eventually did it was to wedge something into the front of the CD/DVD slot so that I wouldn't warp the laptop casing. I used the end of a pen; when wedged in the tip of the pen was the right height to not support the casing above and below the CD/DVD slot and not allow it to warp.
I simply ensured the pen was aligned with one particular clip, lifted the laptop slightly, and squeezed the top and bottom edge of the laptop casing very firmly at that point. Each clip clicked in quite easily doing it this way. Just remember to move the pen (or whatever you are using) along to whichever clip you are clicking in.
David - Contestar
You're on the right track David. But what works really good is something that gets more surface area contact than the pen--I carefully insert a stack of 3" square post-it notes about 3/8" into the slot. And because they're stacked, you can easily add/subtract post-its to get as tight a fit as possible. Then, assuming you have everything lined up, use quite a bit of downward pressure. You should hear a few snaps as the clips reseat.
Citation de David :
John Kassler Niemann - Contestar
John, I didn't think of that. But yeah you are right, it would give it a lot more support.
David - Contestar
I have none of the problems above just was very careful, but inserting the palm rest in first does most of the work , gently does it looking at the alinement of the clips as you go straight in she goes!
swissgrip - Contestar
I would agree with everyone that the clips above the DVD drive are very temperamental. They came off easily for me but were a pain getting to clip back in place correctly.
Make sure you have the front clipped on securely before screwing the case back together otherwise the lid will not close properly.
Nicolas - Contestar
I have taken apart quite a few laptops but this is my first Mac. This confirms my statements, to anyone that will listen, that these are the most "exquisite" machines ever produced. I just performed these HDD Replacement steps and with appropriate fear and trepidation popped the clips off. It would have been very helpful if someone had mentioned that they come straight up. I wasn't sure so I wiggled and (carefully) pried with the spudger until one of them went "POP". The credit card idea was helpful but my card was pretty soft so I didn't dare use it with too much force. When I got the top cover loose I just leaned it back against the screen so as not to take a chance on damaging the cable. Reassembly was according to the notes, but again the spudger was perfect if inserted into the drive slot (careful on the felt!) to support the base of the clips. Thanks to all for the notes. BTW; Prayer helps!
mikedotten331 - Contestar
There is a fifth plastic clip between the IR sensor and the screw hole. (ie. 1 cm left of the IR sensor)
On the top of the case mark the center of each of the four clips that are over the CD slot and the one clip to the left of the latch with a pencil. When re-installing the top case apply pressure over the clip to the left of the latch until you hear a snap. For the four clips over the CD slot, upend the entire case. Then insert the flat end of the spudger into the CD slot under the center of each clip. Apply pressure from the top of the case while providing support with the spudger in the CD slot until the clip snaps in. This will minimize the chances of bending the CD slot which would prevent CDs from ejecting.
danno - Contestar
Take care reassembling new the DVD drive. It's easy to bend the top piece of metal down (the one that engages the clips) and your DVD can get stuck occasional ejecting. Very annoying. Maybe give it a little prophylactic bend upward. I placed a blunt letter opener in the slot and torqued it, while applying downward pressure from the top deck... This allowed the clips to engage nicely without bending this piece down.
davidkkim - Contestar
I use the iSesamo tool to loose the clips, its a very good tool for this and many other things (I don´t work for iSesamo or iFixit hehe).
araujogac - Contestar
i've used both of my inch nails, it works fine as well. no trouble to report.
cnoblemasson - Contestar
i used a pry tool i had left over from replacing the screen on my iphone, any flat stiff item, like a credit card would work. watch the youtube video linked above, http://www.youtube.com/watch?v=jUonF9OSv..., skip ahead in the video to 4:57 where you see her use a pry tool. I had no problem separating and reassembling this section. Only issue i had was the two screws in the battery area. Only one of them would grab, so I left the other one out.
owenmhv - Contestar
Here is an additional video showing how to remove the cables for both the left and right fans. At time 2:00 in the video he starts to work on the left fan. This video will help prevent you from attempting to detach the cables incorrectly.
http://www.youtube.com/watch?v=apn3j3mAR...
owenmhv - Contestar
I've opened these up many, many times, and by far the easiest method I have found to disengage the front clips is as follows:
Lift up the top case by the rear corners near the hinge, keep lifting so the top case is tilting towards you. You will feel some resistance, but keep lifting and you will hear the clips disengage with a 'snap'. Doing it this way should not bend the top case metal or loosen the spacing between the top case metal and plastic trim. The clips will not break, they will still engage when you put the top case back on.
It basically takes me 5 or 10 seconds to take off the top case now, and the case goes back on nice and tight as before.
YMMV and all that, but that's my experience.
Thank you for all the advance warnings, I had no issues with replacing the case. It just snapped into place with a little help from the spudger.
acuella - Contestar
You're welcome! I was the one who added the spudger tips, as I had a devil of a time making the DVD drive clips snap back into place without one when I followed this guide.
CaptFrost -
Hello,
I didn't have much problems reassembling the MacBook. Thanks a lot!
For the hard reassembly part with the clips: I pushed quite hard with both thumbs directly over the place where the clips are. You need to figure out exactly where they are, but it worked well.
I repeat it to make it clear: I pushed from the top on the location under which the clip sat, with two thumbs after having checked that the lid was well in place.
My tools were one spudger and a basic tech toolkit from iFixit.
Thanks a lot!
momogingins - Contestar
I had not problem easing GENTLY the top case from the computer even around the DVD but I didn't understand how easy it was to disconnect the top case from the mother board. TAKE CARE HERE. It will make reassembly much easier it YOU get to disconnect the plug. See my note on step nine
reb - Contestar
Desconecta el  el cable plano del trackpad y del teclado de la placa lógica, retirando la cinta según sea necesario. Nota: Es posible reemplazar el disco duro sin desconectar el teclado del chasis, pero deberá mantenerse en posición vertical para mantenerlo alejado, al mismo tiempo que permite a ambas manos trabajar en la extracción de la unidad.
  • Desconecta el el cable plano del trackpad y del teclado de la placa lógica, retirando la cinta según sea necesario.
  • Nota: Es posible reemplazar el disco duro sin desconectar el teclado del chasis, pero deberá mantenerse en posición vertical para mantenerlo alejado, al mismo tiempo que permite a ambas manos trabajar en la extracción de la unidad.
  • Ten cuidado al retirar el cable plano del teclado-trackpad para asegurarse de que la parte posterior de la carcasa superior esté desenganchada del área cerca de la bisagra. Es fácil doblar accidentalmente los receptores de tornillo a cada lado del teclado.
  • Retira la carcasa superior.
If you does not have the spudger, use the Dremel to file a wooden piece
(Chinese stick maybe) to transform in a spatula. Works fine for me
If you don't have the magic "spudger," try using a plastic (eating) knife.
jpkjpkjpk - Contestar
I read that you can actually also use the corner of a credit card. I didn't have a spudger and this worked perfectly for me. If you hold the card quite close to the corner and it has just the right amount of flex.
David - Contestar
You may be able to unplug the ribbon connector by lifting each end of the tape.
MrSafety - Contestar
Where can I get the cable from step 9 above?
just broke it!
Derry Manley - Contestar
That cable is attached to the upper case. It can be found here for the A1226 and here for the A1260.
Andrew Bookholt -
To unplug the cable, pull the black connector straight up from the logic board.
Robert MacLeay - Contestar
These are instructions for the right Fan. Step 9 mentions the hard drive not the right fan.
karen - Contestar
I didn`t need to unplugged the cable to change the right fan. As Karen wrote above, it is for a fan to change not necessary.
I chose not to disconnect this ribbon cable. I used a chopstick to prop open the front panel; just gently place in lower right corned of case and upper right corner inside the top panel. Saves the risk of disconnecting.
jimmora - Contestar
I didn't look well before the plug connecting top case to motherboard (see my note in step 8). When it came time for assembly it took a while for me to figure out when the plug connected in the motherboard. Take care on step 8 so that YOU have to make the disconnection in step 9. Then reassembly on this step will be much easier.
reb - Contestar
Step 9, 2007 Mac Book Pro right fan replacement. It’s not necessary to disengage the keyboard ribbon, you can just tilt the upper shell back and support it against the screen. Be sure not to put tension on the ribbon and to check that the ribbon “plug” is seated securely on the base before reinstalling the top shell.
These instructions were really great. For $15 I got a used fan off eBay and a Torx T6 driver and Phillips 00 driver from the hardware store. Thanks also for the comment about marking where the plastic clips are by the DVD and IR slot with pencil. When reassembling I slotted a piece of wood (kebab skewer) into the DVD slot and pressed down on the pencil mark with the eraser end of the pencil.
My 10 year old MacBook Pro is going strong. Thanks for these very much. It was fun to do as well.
Kirsten - Contestar
Desconecta los dos o tres cables de antena conectados a la tarjeta Airport Extreme. Dependiendo de tu modelo, uno de los tres cables puede estar sin usar y tapado con un tubo retráctil negro.
  • Desconecta los dos o tres cables de antena conectados a la tarjeta Airport Extreme. Dependiendo de tu modelo, uno de los tres cables puede estar sin usar y tapado con un tubo retráctil negro.
  • Apple tuvo la amabilidad de incluir una etiqueta que muestra dónde se enchufa cada cable de antena de color: solo asegúrate de mirar esto cuando vuelva a conectar los cables de antena.
Agregar Comentario
Retira los cables de la antena Airport de su canal en el altavoz izquierdo.
  • Retira los cables de la antena Airport de su canal en el altavoz izquierdo.
Agregar Comentario
Desconecta el cable iSight de la placa lógica deslizando el cable hacia la izquierda y fuera de su conector.
  • Desconecta el cable iSight de la placa lógica deslizando el cable hacia la izquierda y fuera de su conector.
Agregar Comentario
Apoya la pantalla con una mano mientras quita los siguientes tornillos:
  • Apoya la pantalla con una mano mientras quita los siguientes tornillos:
    • Un tornillo Torx T6 plateado de 9.5 mm con roscas en solo 3 mm del eje en el interior de la pantalla.
    • Un tornillo Torx T6 plateado de 9.5 mm con roscas en todo el eje en el exterior de la bisagra izquierda.
    • Un tornillo Torx T6 con una rosca completa de 9,2 mm que asegura la toma de tierra del cable iSight al ventilador.
When reassembling, ensure that the inverter and iSight cable bundle is underneath of the airport antenna cable bundle.
Erik A - Contestar
For some reason I am having trouble removing the inside Torx screws on both display hinges (One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges). The screws are both loose and turn easily but they won't come out of the hinges. I've tried pulling on the display while rotating my Torx screwdriver counterclockwise but that won't work.
Has anybody else experienced this problem?
Maybelle Kusumoto - Contestar
Desconecta el cable del inversor de la placa de E/S izquierda colocando un spudger debajo del cable y levantándolo.
  • Desconecta el cable del inversor de la placa de E/S izquierda colocando un spudger debajo del cable y levantándolo.
Agregar Comentario
Desconecta el cable de datos de la pantalla de la placa lógica. Retira el parachoques de espuma de la parte superior de la bisagra derecha de la pantalla.
  • Desconecta el cable de datos de la pantalla de la placa lógica.
  • Retira el parachoques de espuma de la parte superior de la bisagra derecha de la pantalla.
Agregar Comentario
Retira el tornillo plateado Torx T6 de 9,2 mm que fija la toma de tierra en el cable de datos de la pantalla a la carcasa.
  • Retira el tornillo plateado Torx T6 de 9,2 mm que fija la toma de tierra en el cable de datos de la pantalla a la carcasa.
Agregar Comentario
Apoya la pantalla con una mano mientras retiras el siguiente tornillo:
  • Apoya la pantalla con una mano mientras retiras el siguiente tornillo:
    • Un tornillo plateado Torx T6 de 9.5 mm con roscas en solo 3 mm del eje en el interior de la pantalla.
Agregar Comentario
Sujeta el ensamblaje de la pantalla en ambos lados y levántalo para sacarlo del ordenador.
  • Sujeta el ensamblaje de la pantalla en ambos lados y levántalo para sacarlo del ordenador.
Agregar Comentario
Retira los tornillos Phillips de 4,5 mm de las esquinas inferiores izquierda y derecha de la pantalla (dos tornillos en total). Estos tornillos tienen una cabeza de .8 mm de grosor. Retira los tornillos Phillips de 4,5 mm de las esquinas inferiores izquierda y derecha de la pantalla (dos tornillos en total). Estos tornillos tienen una cabeza de .8 mm de grosor.
  • Retira los tornillos Phillips de 4,5 mm de las esquinas inferiores izquierda y derecha de la pantalla (dos tornillos en total). Estos tornillos tienen una cabeza de .8 mm de grosor.
Agregar Comentario
Inserta el extremo plano de un spudger perpendicular a la cara de la pantalla entre la tira de plástico unida al bisel posterior y el panel frontal. No insertes tu spudger entre la tira plástica y el bisel trasero. Con el spudger todavía insertado, gíralo hacia fuera de la pantalla para separar los marcos frontal y trasero.
  • Inserta el extremo plano de un spudger perpendicular a la cara de la pantalla entre la tira de plástico unida al bisel posterior y el panel frontal.
  • No insertes tu spudger entre la tira plástica y el bisel trasero.
  • Con el spudger todavía insertado, gíralo hacia fuera de la pantalla para separar los marcos frontal y trasero.
  • Trabaja a lo largo del borde derecho de la pantalla hasta que el marco trasero esté separado del marco frontal.
Agregar Comentario
Inserta tu spudger entre los marcos de la pantalla frontal y posterior en la esquina inferior derecha de la pantalla. Levanta el embellecedor trasero alejándolo del embellecedor frontal para separar ligeramente el borde inferior del embellecedor de la pantalla posterior.
  • Inserta tu spudger entre los marcos de la pantalla frontal y posterior en la esquina inferior derecha de la pantalla.
  • Levanta el embellecedor trasero alejándolo del embellecedor frontal para separar ligeramente el borde inferior del embellecedor de la pantalla posterior.
Agregar Comentario
Inserta el extremo plano de un spudger en el espacio entre el bisel de la pantalla posterior y la cubierta del embrague. Gira el spudger para separar el borde inferior del bisel de la pantalla trasera de la cubierta del embrague.
  • Inserta el extremo plano de un spudger en el espacio entre el bisel de la pantalla posterior y la cubierta del embrague.
  • Gira el spudger para separar el borde inferior del bisel de la pantalla trasera de la cubierta del embrague.
  • Trabaja a lo largo del borde inferior del marco trasero hasta que esté separado de manera uniforme de la cubierta del embrague.
Agregar Comentario
Ahora que los bordes derecho e inferior del bisel posterior están ligeramente separados del bisel frontal, usa un spudger para sacar el bisel posterior de las pestañas cerca de la esquina inferior derecha de la pantalla. Ahora que los bordes derecho e inferior del bisel posterior están ligeramente separados del bisel frontal, usa un spudger para sacar el bisel posterior de las pestañas cerca de la esquina inferior derecha de la pantalla. Ahora que los bordes derecho e inferior del bisel posterior están ligeramente separados del bisel frontal, usa un spudger para sacar el bisel posterior de las pestañas cerca de la esquina inferior derecha de la pantalla.
  • Ahora que los bordes derecho e inferior del bisel posterior están ligeramente separados del bisel frontal, usa un spudger para sacar el bisel posterior de las pestañas cerca de la esquina inferior derecha de la pantalla.
Agregar Comentario
Inserta el extremo plano de un spudger entre el bisel frontal y la tira de plástico unida al bisel posterior cerca de los orificios de los tornillos en las esquinas inferiores de la pantalla. Gira tu spudger hacia el bisel trasero para separarlo del bisel frontal.
  • Inserta el extremo plano de un spudger entre el bisel frontal y la tira de plástico unida al bisel posterior cerca de los orificios de los tornillos en las esquinas inferiores de la pantalla.
  • Gira tu spudger hacia el bisel trasero para separarlo del bisel frontal.
  • Si es necesario, continúa separando el borde izquierdo del embellecedor trasero de las pestañas del embellecedor de la pantalla frontal.
Agregar Comentario
Levanta ligeramente el borde inferior de la pantalla y retíralo del bisel de la pantalla posterior.
Agregar Comentario
Despega la gran pieza de cinta negra de la pantalla LCD cerca de los pestillos en el borde superior de la pantalla.
  • Despega la gran pieza de cinta negra de la pantalla LCD cerca de los pestillos en el borde superior de la pantalla.
  • No es necesario eliminar por completo este trozo de cinta.
Agregar Comentario
Retira las dos piezas de cinta que cubren los cables iSight y la cinta de la cámara cerca de la parte superior de la pantalla.
  • Retira las dos piezas de cinta que cubren los cables iSight y la cinta de la cámara cerca de la parte superior de la pantalla.
  • Mantén presionado el cable iSight mientras retiras la cinta.
Agregar Comentario
Ten cuidado de no dañar el retenedor del cable ZIF a medida que usas el borde de una herramienta de apertura de plástico para voltearlo. Saca el cable iSight de su zócalo en la placa de la cámara. Saca el cable iSight de su zócalo en la placa de la cámara.
  • Ten cuidado de no dañar el retenedor del cable ZIF a medida que usas el borde de una herramienta de apertura de plástico para voltearlo.
  • Saca el cable iSight de su zócalo en la placa de la cámara.
You are better off not unplugging the I sight ribbon cable but unscrew the remote board. unplug the cable that goes to the camera which is the cable next to it. The Isight cable is tough to get back in.
wadeoconnor - Contestar
Primero quita la tira de cinta que cubre el cable iSight. A continuación, despega las tres tiras anaranjadas de la antena del borde inferior de la pantalla LCD.
  • Primero quita la tira de cinta que cubre el cable iSight.
  • A continuación, despega las tres tiras anaranjadas de la antena del borde inferior de la pantalla LCD.
  • Retira las dos piezas de cinta que sujetan el cable de datos de la pantalla a la pantalla LCD.
Agregar Comentario
Desconecta el cable de datos de la pantalla tirando de su conector hacia el borde inferior de la pantalla, lejos de la toma de la pantalla LCD.
  • Desconecta el cable de datos de la pantalla tirando de su conector hacia el borde inferior de la pantalla, lejos de la toma de la pantalla LCD.
Agregar Comentario
Retira los cuatro tornillos Phillips de 3 mm de cada lado de la pantalla (ocho tornillos en total). Retira los cuatro tornillos Phillips de 3 mm de cada lado de la pantalla (ocho tornillos en total).
  • Retira los cuatro tornillos Phillips de 3 mm de cada lado de la pantalla (ocho tornillos en total).
Agregar Comentario
Los siguientes pasos requerirán que separes la pantalla LCD del adhesivo aplicado a los bordes superior e inferior del bisel frontal.
  • Los siguientes pasos requerirán que separes la pantalla LCD del adhesivo aplicado a los bordes superior e inferior del bisel frontal.
  • El adhesivo se aplica de manera que se adhiere a una fina franja de acero alrededor del perímetro de la pantalla LCD. Cuando extraigas tu LCD del panel frontal, asegúrate de separar el panel frontal de la banda de acero en la pantalla LCD.
    • ¡No hagas palanca sobre el borde del marco ya que está hecho de aluminio y puede doblarse muy fácilmente!
  • Usa el extremo plano de un spudger para levantar suavemente una de las esquinas superiores de la pantalla LCD del marco frontal.
Agregar Comentario
Sigue su camino a lo largo del borde superior de la pantalla LCD, haciendo palanca lentamente hacia fuera de la tira de acero adjunta del bisel frontal.
  • Sigue su camino a lo largo del borde superior de la pantalla LCD, haciendo palanca lentamente hacia fuera de la tira de acero adjunta del bisel frontal.
Agregar Comentario
Ahora que el borde superior está libre, levanta ligeramente la pantalla LCD del bisel frontal para obtener suficiente espacio para hacer palanca en la banda de acero a lo largo del borde inferior de la pantalla LCD, lejos del panel frontal. Haz palanca a lo largo del borde inferior de la pantalla LCD hasta que se libere del adhesivo en el bisel frontal.
  • Ahora que el borde superior está libre, levanta ligeramente la pantalla LCD del bisel frontal para obtener suficiente espacio para hacer palanca en la banda de acero a lo largo del borde inferior de la pantalla LCD, lejos del panel frontal.
  • Haz palanca a lo largo del borde inferior de la pantalla LCD hasta que se libere del adhesivo en el bisel frontal.
  • Evita tirar del borde de la unidad LCD desde la pantalla. Asegúrate de insertar la herramienta entre el metal del bisel y el metal de la pantalla LCD. Si el adhesivo está muy fuerte, haz un par de tirones suaves en el borde inferior para evitar aplicar demasiada presión.
Be warned: Indeed, very ""slightly"" lift the LCD out of the front bezel for just ""enough"" room to pry the steel strip along the lower edge of the LCD away from the front bezel. If you lift too much there is a chance you might bend and crack the fragile aluminum bezel sides close to the lower edge. It happened to me, the glue in the lower edge was strong enough to bend the sides. I was easily able to find an inexpensive replacement bezel, but had to impatiently wait almost 1 month to get it... so be careful... and tank's for these guides.
Jean Roch Blais - Contestar
Levanta la pantalla LCD del bisel frontal, teniendo en cuenta los cables que puedan quedar atrapados. Nota de Reemplazo: hay calzas de plástico transparentes unidas mediante adhesivo a los lados y la parte inferior del panel LCD. Asegúrate de transferir estas calzas al panel de reemplazo para un ajuste óptimo.
  • Levanta la pantalla LCD del bisel frontal, teniendo en cuenta los cables que puedan quedar atrapados.
  • Nota de Reemplazo: hay calzas de plástico transparentes unidas mediante adhesivo a los lados y la parte inferior del panel LCD. Asegúrate de transferir estas calzas al panel de reemplazo para un ajuste óptimo.
  • No te olvides de transferir el pequeño imán conectado al lado derecho de la pantalla LCD a tu nueva pantalla LCD. La ausencia de este imán evitará que tu MacBook Pro entre en modo de reposo.
    • Dependiendo del modelo de tu ordenador portátil, el imán puede estar ubicado dentro de un orificio en el marco frontal, no en la pantalla LCD. Ver segunda imagen.
Warning, there is small magnet on right side of LCD. Do not forget to place it back with new LCD.
I accidentally removed it with old LCD, it sticked to it, and now MacBook do not sleep when closing lid. I need to reassemble it again.
Vladimir Silantyev - Contestar
Yes very important if it were not for his post the same fate would have been mine. This was a lot easier than I thought!
Quote from Vladimir Silantyev:
sharppay - Contestar
I do not see the magnet, a photo would be nice.
amccombs - Contestar
Sorry i did not take any pictures, trust me it is there and you cant miss it.
Quote from amccombs:
I was looking for a black magnet, but it is a small silver (like aluminium) piece that fits in the aluminium rim. long shaped and rounded.
ricardo di parodi - Contestar
My magnet was stuck in the frame. The longest step of this was 15 minutes looking under all the tape on the old LCD trying to find this mythical magnet stuck somewhere that I had no idea what it looked like.
I tried editing the wiki to add that the magnet was silver and oblong, and that it could be stuck in the frame. Does this require an admin of some sort to edit?
Very nice guide besides that, thanks!
helpdesk - Contestar
Goodness, like many readers my longest step was looking for that unicorn magnet. I finally found it... In a perfectly shaped hole for it on the right side of the BEZEL. Not of the LCD. Ugh. Check there.
I also tried to edit in a sub-bullet and a photo that I snapped of my magnet to no avail.
BeckyG - Contestar
It looks like my photo was eventually added! Hopefully that is/will be helpful to future users.
BeckyG -
Conclusión
Para volver a montar tu dispositivo, sigue estas instrucciones en orden inverso.
138 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
I didn't have any trouble getting this apart - I used a small screwdriver from a jewelry repair kit (the set of six super small screwdrivers). I slide it in on the left front where it was open and slid it towards the IR thing. After that clip opened up I just slid it over towards the DVD drive... presto. Will update when I put this back together in a couple days. This guide should warn in the beginning to keep the screws identified in some way or you'll have a %*^! of time putting it back together.
Isaac - Contestar
I didn't have a spudger handy, but I got by just fine using an old credit card. Don't use a current one, as I dented up the edges pretty good in the process.
I've disassembled many a pc laptop without instructions, but macs are special ;) it was very helpful to have all the details spelled out for me. Thanks!
Seth - Contestar
Confirming Success #44.
While I would advocate for good lighting, non-geriatric eyes, or a vision headset, and serious patience, I do not thing this was extremely difficult. I'm 66. Took my time, and it came up ok.
jimjarvis - Contestar
By the way, a heavy guitar pick works well as an alternative to a spudger. Keep one rounded and file another one to a point for removing the cable connections/ zif connections etc. I have been using these now for a few repairs and they work really well.
Steve - Contestar
Be very carefull and bee patience. It´s very helpfull to have something like the ifixit magnetic project mat to keep the screws in order, otherwise you will have a hard time to put the parts together.
Guenther Roppele - Contestar
I've had a strange problem putting the screen back into the computer. I was swapping out a damaged screen from another macbook pro and had tested both screens, cables, etc. and screen was coming on when machine was fired up. However, as I was also replacing the front screen bezel I also had to remove the front hinge clutch. Each time something happened when putting the screen clutch back on and firing up the computer. Every time I did this, with different cables, different combinations, I was left with a black screen. I would take it all apart again, switch cables, test the screen (working now) then put the cables back in, boot up and black screen again. I can't figure out what I have done wrong. Could I be triggering some current and shorting something when doing this? Dave
dvdesmond - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 51
Últimos 30 Días: 201
Todo El Tiempo: 112,216
