Introducción
Replacing the metal bottom case.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Agregar Comentario
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
Tip for new players - print this guide, then use Sello tape to tape the screws from each step on the picture. Keeps them all organised and easy to know which screws belong to which step when putting it all back together
MPB Monkey - Contestar
Thanks a lot for this great advice. I followed it, and it turned out to be very useful and practical.
Ralf Bergs -
Quote from MPB Monkey:
"...Tip for new players - print this guide, then use Sello tape..."
It's one word: Sellotape, the biggest brand in Europe. :-)
matthk - Contestar
In regard to the incredible amount of TINY screws, get an Ice Cube Tray or something with AT LEAST 8 compartments, then, when taking out the screws, mark EACH compartment with the step # and how many screws that were taken out, and used for THAT STEP (such as Step # 3 = 4 of 4 screws. Label EACH compartment, and keep them in line of each step. When it comes time to put everything back together, just reverse your Ice Cube Tray, and follow the Steps in Reverse!
As far as marking each compartment, try these POST IT PENS!!!
http://www.staples.com/Post-it-Flag-Ball...
GOOD LUCK! Take your time, it's not as difficult as it seems!
JerseyJeepGurl
JerseyJeepGurl - Contestar
An ice cube tray is definitely the way to go!
Martok Bulls -
This guide helped me to remove the keyboard on my MBP, but it doesn't take you further to take the keyboard apart. If you REALLY want to look inside the keyboard, you'll need to remove additional phillips screws (10), and carefully remove the inner plastic/clear layers inside the keyboard.
I did this to look for physical damage inside the keyboard and noticed that the black plastic? sheet was torn on my letter 'v', which was one of the keys not working. I did not see any physical sign anywhere else on the keyboard, though.
So, after pulling the defective keyboard away and installing the new one purchased from iFixit, putting everything back together is not too difficult, just reverse.
One thing, though: Check and double-check before you tighten the case screws to make sure your keyboard backlight is working. I noticed I had forgotten to plug it in, luckily for me before I put all the screws on the case.
To avoid losing any screws, print this guide and use clear tape to tape the screws next to the step. Use double-tape to avoid tearing or one of the tiny screws from falling out.
Good luck!
Thanks iFixit for helping me replace my MBP's keyboard!
juanortuno - Contestar
Thank you for some excellent advice form JerseyJeep Gurl
Quote from SubodhJ:
SubodhJ - Contestar
Worked perfect on my 4,1 mbp. Took ~15 min.
I don't see a boost in speed... or is just me?
I used 500 GB 7200 RPM Seagate SATA Hard Drive model ST9500420AS.
(if has a G letter at the end (ASG) is the one with built in shock protection who conflict sometimes with the mac own G protection).
crus - Contestar
This guide was awesome. I used JerseyJeepGurl's suggestion and used an egg carton, numbering each cavity as a step in the guide. So for a step that had me remove 3 different kinds of screws, I had a cavity for each, numbered: 1a, 1b, 1c and wrote a,b,c on the guide itself next to each bullet point in the step. It was awesome.
I guess that before starting I overlooked what a T6 torx actually was. I started this process at 8pm and realized right away that I did not have a set that small and of course all stores were closing. Lowes actually had an awesome fine torx driver set for only 7 bucks!
So that you fixit.
tech4eleven - Contestar
Quote from tech4eleven:
So that you fixit.
Thank you everybody for "thanking me" on the compartment advice! Also, just about ANY Auto parts store will have a set of Torx Screw drivers, in a handy little set, that is all together. Good luck everybody,,remember,TAKE YOUR TIME, BREATH, AND DON'T GET FRUSTRATED!!! (STEALING ADVICE FROM PEARL JAM,,BREATH,JUST BREATH),,,,AND YOU'LL BE ABLE TO DO IT YOURSELF!
JJG
Quote from JerseyJeepGurl:
JerseyJeepGurl
Michael Fredrickson - Contestar
Quote from Michael Fredrickson:
I get a piece of "corrugated" cardboard and draw an outline of the laptop and all the "compartments" that are accessed. When you take a screw out simply punch it threw top layer of the cardboard exactly where it goes. Multiple compartments - just draw another diagram on the cardboard. Voila!
I just finished replacing my hard drive following these instructions and they were perfect. The only minor complication involved the ribbon cable connecting to the sleep light and IR sensor connectors. The entire cable was tightly glued to the hard drive. But I got it loose with 10 minutes of gentle prying with a spudger.
To keep track of the screws I just sketched an outline of the bottom panel, taped the screws in the right places and numbered them with the step numbers.
Tom McAuliffe - Contestar
I just used that Glad Press' N Seal. I just cut a 4 in piece, cut slits in it to about half way, Put the screws on there, and fold the pieces over the screws. You can number them, i just kept track of them. Also, you might not need that much, i just cut that much just to be safe.
benchallinor27 - Contestar
I use magnet
I use the magnet that close the refigerator door.
The screws are put on the magnet, so it didnot fall from the table.
i am french so sorry for my english
Madoc -
Just another idea for a container for all the little screws: pillbox. I got one for about $1.00 at the store with 14 compartments.
Brian Littmann - Contestar
Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Agregar Comentario
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Agregar Comentario
Remove the following 6 screws:
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
Agregar Comentario
Remove the four 3.2 mm Phillips screws on the port side of the computer.
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
"port side of the computer" should read "starboard side". It's on the right-hand side when the computer is positioned normally in front of you.
joeycoole - Contestar
Port side as in I/O port side, as in the side that has the FireWire and ethernet ports. This is a MacBook, not a sailboat ;)
Andrew Bookholt -
Maybe I'm too used to running flight simulators on my Macs. But to us sailors or pilots, it would perhaps be clearer if the instructions mentioned "I/O port side" as Andrew did above.
Honestly, it never crossed my mind that 'port' refered to in/out…
joeycoole -
Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
Agregar Comentario
Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
In my machine the screw closest to the power connector had a slightly thicker head, and would not sit flush, upon reassembly, unless it was returned to the same hole.
Martin Kenny - Contestar
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Be super careful not to bend the metal tabs that hook the upper case into the lower case. If bent these make it challenging to close and reattach the upper case.
lama - Contestar
I had already done this once and now have a larger SSD to put in and cannot get past this step as the back just will not pop off. In fact- the front comes off fine but the back, where you cannot get the spudger, is "glued" or wedged solid. I suspect that the rear screw tabs have jammed. :(
Stefanie - Contestar
I would not rock the case up and back. There are 4 plastic connectors that need to come loose, start on the left side with a spudger about a quarter of the distance from the edge and pop them up from left to right, one by one.
maccentric - Contestar
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
Kudos for this fantastic walk-through of replacing the hard drive. I just swapped in a new SSD and it was a piece of cake!
On Step 10, I tried just propping up the keyboard and leaving it connected to the logic board. It worked for a while but eventually the ribbon popped off. Luckily it wasn't damaged and it's super easy to replace.
DJR - Contestar
Same happened to me. No damage here either. :-)
Ralf Bergs -
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Agregar Comentario
Remove the following 4 screws:
  • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
Regarding the following instruction: -
Be aware there are two of these on the bottom (if the slot is facing you) screws close to each other, one is for the actual drive assembly itself and the other is attaching the drive to the Mac. Beware you choose the correct one.
spaceshipdev - Contestar
Lift the optical drive up and out of the computer.
  • Lift the optical drive up and out of the computer.
Agregar Comentario
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Agregar Comentario
Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
  • Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
Agregar Comentario
Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
  • Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
Be careful when putting the logic board back into place, you can easily overlook the small cable that fits at the top, otherwise you have the frustrating experience of having to remove all the screws again!
sfuseau - Contestar
On putting this back together, I'm finding the small upper cable that presumably is battery monitoring (lower left hand corning of the picture) is not staying in place (I'm using the one that shipped with the lower tray, not the original). I'm thinking either some of the anti-static tape, or a rebending of the wires to help apply continuous pressure. I had to take the top off one already as a consequence of this, as it wouldn't power-up on battery alone, and the next day, the problem appears to have returned.
schurger - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
  • Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
Agregar Comentario
Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
  • Lift the clear plastic shield off the right ambient light sensor.
Agregar Comentario
Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
Agregar Comentario
Remove the following 15 screws:
  • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
In the diagram, the yellow circle and the orange next to it should be swapped. The black screw won't even grasp the threads in the indicated hole.
Monica Anderson - Contestar
where the foto of step 20??!! (
kohaua - Contestar
The five red rings indicating the screws on the left and right fan should be green not red.
cgriffin - Contestar
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
  • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
  • Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
Agregar Comentario
Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
  • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
  • Remove the right fan from the computer.
Agregar Comentario
Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
  • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
Agregar Comentario
Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
  • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
  • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
Agregar Comentario
Lift the heat sink out of the computer.
  • Lift the heat sink out of the computer.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Agregar Comentario
Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  • Remove the left fan from the computer.
Agregar Comentario
Disconnect the three antenna cables attached to the Airport Extreme card.
  • Disconnect the three antenna cables attached to the Airport Extreme card.
  • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
Agregar Comentario
Deroute the Airport antenna cables from their channel in the left speaker.
  • Deroute the Airport antenna cables from their channel in the left speaker.
Agregar Comentario
Remove the single black T6 Torx screw located just above the Airport Extreme card.
  • Remove the single black T6 Torx screw located just above the Airport Extreme card.
  • Lift the small silver metal retaining bracket up and out of the computer.
Agregar Comentario
Lift the Airport Extreme card up and slide it out of its connector.
  • Lift the Airport Extreme card up and slide it out of its connector.
Agregar Comentario
Peel up the orange hard drive cable from above the ExpressCard cage.
  • Peel up the orange hard drive cable from above the ExpressCard cage.
Agregar Comentario
Disconnect the speaker cable from the corner of the left I/O board.
  • Disconnect the speaker cable from the corner of the left I/O board.
Agregar Comentario
Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
  • Carefully peel up the black adhesive tape securing the speaker cable along the rear edge of the lower case.
Agregar Comentario
Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
  • Continue to free the speaker cable from the black tape until it is free from all three sections of tape.
Agregar Comentario
Remove the single black T6 Torx screw securing the right speaker to the lower case.
  • Remove the single black T6 Torx screw securing the right speaker to the lower case.
Agregar Comentario
Use a spudger to pry up the right speaker from the lower case.
  • Use a spudger to pry up the right speaker from the lower case.
  • Remove the speakers from the computer.
Agregar Comentario
Support the display with one hand while removing the following 3 screws:
  • Support the display with one hand while removing the following 3 screws:
    • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
Agregar Comentario
Grasp the display assembly on both sides and lift it up and out of the computer.
  • Grasp the display assembly on both sides and lift it up and out of the computer.
Agregar Comentario
Disconnect the IR and sleep light cables from their connectors above the hard drive.
  • Disconnect the IR and sleep light cables from their connectors above the hard drive.
Agregar Comentario
Remove the two silver Phillips screws securing the hard drive retaining bracket to the lower case.
  • Remove the two silver Phillips screws securing the hard drive retaining bracket to the lower case.
  • Lift the hard drive retaining bracket up and out of the computer.
Agregar Comentario
Lift the hard drive up from the right side and remove it and the attached cable from the computer.
  • Lift the hard drive up from the right side and remove it and the attached cable from the computer.
Agregar Comentario
Remove the following 7 screws/standoffs:
  • Remove the following 7 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • Two silver T6 Torx screws securing the battery connector to the lower case.
    • One 4 mm standoff located between the audio jacks.
Agregar Comentario
Lift the left I/O board up from the right side and slide it out of the computer.
  • Lift the left I/O board up from the right side and slide it out of the computer.
Agregar Comentario
  • Peel up the orange Kapton tape covering the right thermal sensor.
  • Use a spudger to pry the right thermal sensor off the lower case.
Agregar Comentario
Use a spudger to pry up the PRAM battery off the lower case.
  • Use a spudger to pry up the PRAM battery off the lower case.
Agregar Comentario
Lower case remains.
  • Lower case remains.
Agregar Comentario
Conclusión
18 personas más completaron esta guía.
iRobot
Miembro Desde 24/09/09
1 Reputación
750 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 24,580
