Introducción
utilizar esta guía para reemplazar una cubierta de embrague de plástico dañada.
Retire los siguientes 10 tornillos que sujetan la caja inferior al MacBook Pro 13 "Unibody:
  • Retire los siguientes 10 tornillos que sujetan la caja inferior al MacBook Pro 13 "Unibody:
    • Siete tornillos Phillips de 3 mm.
    • Tres tornillos Phillips de 13,5 mm.
It looks like you need a Phillips #000 screwdriver for the 10 bottom screws. I tried the #00 and it's too big. Good thing I bought a 23 piece precision screwdriver set or else I would have been screwed.
scott523 - Contestar
The 10 screws that hold tha bottom case take a #00 Phillips driver, if yours doesnt fit it's probably because it's cheaply made & not precise enough. The only thing that I needed a #000 driver for was the keyboard screws. They're so small they look like specks of dirt or sand. I stripped out 4 of them & now will need to grind the heads off with a Dremel/rotary tool. The other thing that sucks is iFixit doesn't have a tutorial for keyboard replacement!
iphonetechtips -
A true Phillips head screw's slots are rounded at their inner corners, to allow the screwdriver to "cam out" (pop out) of the screw head before you apply too much torque and strip the threads in the part that you're torqueing the screw into. However, the screws used in the Macbook don't have those rounded inner corners, so they're not Phillips. Instead, they may be a Japanese standard known as JIS B 1012, or a Frearson (also known as a Reed & Prince), but that's a less common design. Maybe technically these non-Phillips screws should be used with a screwdriver that was specifically designed for them, but they can be properly removed and reinstalled using a truly precision-made Phillips #00 (some people find a #000 sometimes works even better) whose tip comes to a sharp point--not the lousy fake "precision" screwdrivers that are sold in too many places. See my next comment for more.
johnsawyercjs -
Many screwdriver manufacturers get away with marketing fake "precision" screwdrivers because, in the words of the Wikipedia article at https://en.wikipedia.org/wiki/List_of_sc...: "Most heads come in a range of sizes, typically distinguished by a number, such as "Phillips #00" or "Torx T5." These sizes do not necessarily describe a particular dimension of the drive shape, but are often arbitrary designations in the same sense as a "Size 8" dress."
In other words, the quality of many "precision" screwdrivers is poor. In my experience, one of the biggest problems with many fake "precision" Phillips screwdrivers is that the four blades at the tip are often too wide, and their width may even vary on the same screwdriver (they're not supposed to). So just because a screwdriver is marketed as a "precision screwdriver", it may not be, and many that are labeled as #00, or even #000, will not work for a Macbook's screws. See my next comment for still more.
johnsawyercjs -
One of the best manufacturers of precision screwdrivers is Wiha (http://www.wihatools.com/tech-tools/prec... cost more, but they're worth it. Or buy screwdrivers from iFixit, who seem to be selling JIS screwdrivers.
Another article with some good info on screw and screwdriver types:
http://www.instructables.com/id/When-a-P...
Also keep in mind that some screws are tougher to remove and reinstall because they have a thread-locking compound on them, which is usually blue.
johnsawyercjs -
Phillips #00 is the correct screwdriver for the lower case. Maybe the one you have is worn or badly made.
David Fear -
Perfect man!Many thanks!:)
wertaerte - Contestar
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
twisk - Contestar
thanks twisk, I wish i would have read your tip before I finished putting the bottom of my laptop back together. I managed to get all screws in somehow, but one was in fact too-tight.
BTW, big big thanks to the Author: Andrew Bookholt. Just used this guide and my trackpad now works again.
xitxit2 -
i too need a #000 for the bottom of the case -- i got the recommended screwdriver (#00) and unfortunately it's too big
plins718 - Contestar
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - Contestar
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
The colours you used for these circles are indistinguishable for colour-blind people. Please consider using something like the palette suggested by visibone: http://www.visibone.com/colorblind/
Eric Sorenson - Contestar
Squares, Circles, Triangles (you get the idea) would work as well to distinguish the different screws.
danzeitlin -
I'd use a Phillips #000 screwdriver also. The #00 can work, but if the screws are in really tight, it doesn't get far enough down into the screws to get purchase, so it will start to strip (and I agree that the screws are pretty soft). On mine, the screws for the fan were really tight, started to strip with #00, needed a #000 and quite a bit of pressure to get them to move.
jonathanmorgan - Contestar
I thought it took a 000 as well. However, I tried both and realized the 00 works best.
john - Contestar
Hi i was wondering if you can add 16gb to this model? or is 8 the maximum?
Igor - Contestar
The Mid 2010 MacBook Pro 13" does support 16 GB RAM, but it is very picky about the type of RAM. OWC sells a 16 GB kit (2x 8 GB). I think it's got to be 1066 (aka 1067) MHz RAM. A lot of 8 GB modules on the market now are faster than 1066 MHz, and reports I've read say people start getting kernel panics if they use the wrong RAM.
Some info here:
http://www.everymac.com/systems/apple/ma...
"1066 MHz PC3-8500 DDR3 SDRAM"
"*Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM."
Our Mid 2010 already had "the latest EFI" (i.e. Boot ROM version in System Profiler), so the reference to updating it may not be relevant.
Winston -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - Contestar
I had the same problem. The #00 screwdriver worked for some of the screws but some others were too tight and I had to use a #000. Maybe it was because the cover had slightly bent because the battery inside had basically doubled its width, but I still found that the #000 was a much better fit for these screws. Even the ones that came out with the #00 came out much easier with the #000. I would suggest updating this guide to suggest using a #000.
tarriojuan - Contestar
Had no idea they were so expensive.
Franklin - Contestar
Phillips #00 is the right tool for all the steps (Except the 4 HD T6 screws). Maybe there is dirt in the notch.
Luis Soto - Contestar
There is any chance to use the Toshiba MQ01ABD 1 TB 2.5" Internal Hard Drive MQ01ABD100 , it has7200 rpm , shuold it work?
Luis - Contestar
If you are running OS X 10.11.2 or newer, battery provided by iFixIt will not work. I've already tried 2 batteries from iFixIt and neither worked. iFixIt needs to come clean on this unfortunate situation. I've already put 8 hours into this futile effort when it should have taken me 45 minutes.
gkofga - Contestar
What was your solution? I'm using 10.11.3 OS X. I may need a battery replacement very soon too.
John Doe -
<i>The 10 screws that hold that bottom case take a #00 Phillips driver, if yours doesn't fit it's probably because it's cheaply made & not precise enough.</I>
I purchased the IFixIt 54 bit Driver Kit and their Phillips #00 are <b>NOT</b> the appropriate size for the bottom screws on this MacBook Pro. This manual needs to have the tools changed to Phillips #000 Screwdriver. Until then I shall not click the "Give the author +30 points" button. Apart from that, the rest of the manual is very good. It would also be an idea to make a comment about making sure the battery connector is in the correct position when plugging the battery back in. One poster commented that their battery will not charge anymore. My guess is a pin(s) was/were bent due to the connection not being in the vertical orientation when being pressed back together. :-)
THANK YOU for writing and generously supplying this guide for our use. It is much appreciated. +30 point coming when the Phillips #000 size is changed or added.
Joseph King - Contestar
It would be nice to remind fixers which length screws go back in which holes, in case they get mixed up...
Mike - Contestar
Levante ligeramente la caja inferior y empuje hacia la parte posterior para liberar las lengüetas de montaje.
  • Levante ligeramente la caja inferior y empuje hacia la parte posterior para liberar las lengüetas de montaje.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
Mike - Contestar
Por razones de precaución, le recomendamos que desconecte el conector de la batería de la placa lógica para evitar cualquier descarga eléctrica.
  • Por razones de precaución, le recomendamos que desconecte el conector de la batería de la placa lógica para evitar cualquier descarga eléctrica.
  • Utilice el extremo plano de un spudger para levantar el conector de la batería hacia arriba fuera de su toma en la placa lógica.
why is step 3 necessary?
gansodesoya - Contestar
Quote from gansodesoya:
Just to disconnect any power source to avoid damages by short-circuits.
MrKane - Contestar
Removes the possibility of any current flow. This is especially important if you are trying to mitigate the damage to the circuitry due to a spill on a keyboard.
amiller770 - Contestar
I'm thinking of ordering the spudger. I was thinking of order the heavy duty spudger... or should I just order the normal. Will either of the spudgers work for this DIY?
shockaaa - Contestar
Once you have a set of spudgers, you will wonder how you ever went without them. :-)
Brian -
$@$@. Don't use an non-isolated screwdriver for this. I just shorted-out my battery :(
Lukas Besch - Contestar
You are absolutely right, never use a screwdriver on the logic board or any connector! Delicate use of fingernails or a credit card will get you through most situations if you lack a spudger.
Logan Bean -
How do you get that battery connector back on? Do you just press it in back in place after you're done?
Horace Chung - Contestar
yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
maccentric -
Would it not be advisable to drain the battery completely before attempting to repair, if you want to be sure you don't get a spark when removing the battery connector?
Berlugana
bduault - Contestar
Disconnecting the battery connector is not that different from simply unplugging a battery from an older model MacBook with a removable battery. You're not trying to protect yourself from a "spark", but the internal circuitry when taking the MacBook apart.
amiller770 -
I neglected step 3 and now my computer won't turn on. Could I have shorted out my logic board?
Plamen - Contestar
I had the same problem , my macbook doesn't switch on working
marioluiggi -
A very easy and fast update indeed! Using this guide and the tools indicated on top I replaced the two RAM cards (2GB each) with two 8GB RAM cards from OWC for a total of 16GB RAM in my MBP Middle 2010 Core 2 Duo (Officially not supported according to Apple).
Make sure you select RAM with these specs: 16GB DDR3 PC8500 1066MHz Kit (8GBx2)
Apps open much faster and I can run a virtual machine at a decent speed.
Removing the battery is not required, but in some instances can make installing ram much easier. If you plan on upgrading from 4GB (2X 2GB) to 8GB (2X 4GB) Removing the battery would be better. There are two levels of ram. If you are replacing both levels, then remove the battery. If you are just replacing the top, dont bother. Removing the battery for very long or even at all (depending on the CMOS battery age and health) could possibly reset settings, the clock, saved wifi passwords, and more.
Everett Whiteman - Contestar
It is beneficial to remove the battery at this stage.
Knox Karima - Contestar
This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
Jeff Diamond - Contestar
Guys I just used my index finger nail. It’s the most useful nail to let grow a little bit for this type of procedure. Came off pretty easy when using both my right hand index and left hand index together to lift the plug up out. Found some plastic folded it and place it right over the socket so the plug would go back in and now the plug holds the plastic in place so I can focus on the main work.
clsmithj - Contestar
Utilice el extremo plano de un spudger para mover el subwoofer / conector del cable del altavoz derecho hacia arriba fuera de su zócalo en la placa lógica. Tenga mucho cuidado de presionar debajo del conector como se muestra, y no debajo del enchufe en sí. De lo contrario, puede separar accidentalmente el zócalo de la placa lógica. Tenga mucho cuidado de presionar debajo del conector como se muestra, y no debajo del enchufe en sí. De lo contrario, puede separar accidentalmente el zócalo de la placa lógica.
  • Utilice el extremo plano de un spudger para mover el subwoofer / conector del cable del altavoz derecho hacia arriba fuera de su zócalo en la placa lógica.
    • Tenga mucho cuidado de presionar debajo del conector como se muestra, y no debajo del enchufe en sí. De lo contrario, puede separar accidentalmente el zócalo de la placa lógica.
You must first separate the little foam pad to see better how to pry the cable
connector up. You must be
careful not to root up also its socket
stuck on the logic board
ramonananos - Contestar
My subwoofer/right speaker connection seemed to be soldered on the main board. Of course, I pried this off..realizing right after that there was no reconnecting it (&^$%^@!). There's really no reason to even disconnect this wire on the MacBook pro 13 mid-2009
Glad this is my "project" Mac
srlincoln - Contestar
Please Be Carefully With This Step, Because I Had To Resolder It Back To The Logic Board. But There Is A Black Foam Piece Over The Cable You Have To Pry Up, Lift The Foam Piece And Then Try To CAREFULLY Pry Cable Connector
BWilliams842 - Contestar
A better description would have been worth a lot....
I accidently pried off the socket aswell... gonna have to go to the computer/robotics lab at my college to resolder it -.-
Juliane Aschenbrenner - Contestar
I didn't have to do step 4 for my mid-2010 13" mbp.
jonk2015 - Contestar
CAUTION!! Note is required here! First off step is truly unnecessary! Secondly, just don't do it!
Edward Turkovich - Contestar
A real closeup photo of this small piece of hard plastic that prevents the connector from falling out would be a great help. !
Peter Mayo - Contestar
Don't follow this step!!!! It is complete unnecessary. I just riped of the socket....
hilbert - Contestar
Thank you for the warning not to perform this step. It is unnecessary to unplug that connector.
Fill IP - Contestar
Desconecte el cable de la cámara retirando el extremo macho directamente desde su socket.
  • Desconecte el cable de la cámara retirando el extremo macho directamente desde su socket.
    • Hay un pequeño pedazo de plástico duro pegado a la tabla lógica que para el cable de la cámara de caerse de su zócalo. Asegúrese de pelar esto primero o podría dañar los conectores.
  • Asegúrese de halar el conector paralela a la cara de la tabla lógica y hacia la unidad óptica, no directamente desde su zócalo.
Be careful to the piece of plastic that prevents camera cable failing out its socket! Do not force connector! Look at plastic before attempting to remove connector Plastic is partially covered by cdrom flat connector at right of camera cable connector
Silvio - Contestar
that's not only the camera but the wifi and bluetooth too. Be extremely careful!
Jose Luis Blas - Contestar
So I unfortunately did not find this guide when I was replacing my keyboard. I did at first force this connection, didn't know I could peel that black plastic piece off, then was able to smoothly get it in. Now my Bluetooth/Wi-Fi/web cam isn't working. I'm looking at the connection now and it looks undamaged. How do I know for certain I damaged the cord and/or socket
Vic - Contestar
Does anybody knows how I can change the cable+connector, and where to buy it? Thanks
Guillermo - Contestar
It would be so helpful if a real closeup of the hard piece of plastic that keeps the connector in place were included. In the photo. it looks to be almost where
the guys fingernail is in the photo and close to the screw near the top edge of the connector, is that correct ?
This step is unnecessary. And the connector is very very fragile. Don't follow this step.
hilbert - Contestar
The comment above from hilberg is wrong. You should disconnect this plug, otherwise one can not detach the screen later.
Fill IP - Contestar
Please be VERY careful. I fixed my Macbook Pro A1278 Backlit Keyboard but lost my WiFi/Camera/Bluetooth…
Caio Carvalho - Contestar
Desvíe el cable de datos de la cámara del canal de la unidad óptica.
  • Desvíe el cable de datos de la cámara del canal de la unidad óptica.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Retire los siguientes tornillos que sujetan el cable de datos de la cámara y el altavoz derecho a la caja superior: Dos tornillos Phillips de 8 mm.
  • Retire los siguientes tornillos que sujetan el cable de datos de la cámara y el altavoz derecho a la caja superior:
    • Dos tornillos Phillips de 8 mm.
    • Un tornillo Phillips de 4mm.
  • Uno de los tornillos Phillips de 8 mm probablemente permanecerá cautivo en el bucle de tierra del cable de la cámara.
  • Resbala el soporte del cable de la cámara hacia afuera desde debajo del subwoofer y retírelo del la computadora.
For my mid-2010 mbp, removing the 4mm screw is not enough as the camera cable bracket is under the black cover. I need to unscrew another screw (see the dark cover in step 6). However, the speaker (dark circle in step 6) is a strong magnet and the little screw flew onto it and crack the speaker slightly. You need to be very careful of this. The sound wasn't as clear when I turn on loud volume after that.
in my case the 8-mm screw was stuck. I needed to drill the head.
Fill IP - Contestar
Be careful when taking off the screws here. When I was taking apart the bracket, one of the screws became severely stripped (to the point where it was rounded. I had to wait to wait until my father got home so he can give me his screw extracting tools. The same can be said for the display cable bracket ( but that one wasn’t such a big deal for me since I didn’t severely strip it, a bigger screwdriver helped out for me.)
Willie Narvaez - Contestar
Agarre la lengüeta de tracción de plástico asegurada al bloqueo del cable de datos de la pantalla y gírela hacia el lado DC-in del equipo. retire el conector del cable de datos de la pantalla directamente de su toma. Asegúrese de tirar del conector directamente y no hacia arriba de su toma.
  • Agarre la lengüeta de tracción de plástico asegurada al bloqueo del cable de datos de la pantalla y gírela hacia el lado DC-in del equipo.
  • retire el conector del cable de datos de la pantalla directamente de su toma.
  • Asegúrese de tirar del conector directamente y no hacia arriba de su toma.
Well, my display ended up looking like this after the repair:
http://i1106.photobucket.com/albums/h366...
As you can see, there was a light/dark banded pattern along the bottom of the screen, corresponding to the LCD's backlight. In my case it was also accompanied by a constant high pitched whistling noise. I swear to anything that's holy, it was not coming from the fan or the speaker, but rather the motherboard itself.
Anyway, both these problems went away when I disconnected and reconnected the connector at this stage. I'm saying this on the off chance it helps someone else.
Jonty Levine - Contestar
I did what you said, disconnect and reconnect the display data cable but the problem didn't go away. Any idea how to fix this?
jonk2015 -
I also encountered the issue at the bottom of the screen. I can't get mine to go away. I can make it vary a bit or at least the whole display to vary by fluctuating the connection, but it just won't go away. I'm open to any other suggestions.
I might have manhandled the bottom of my screen a bit. I didn't realize how to get the plastic u-shaped cover off, and I fudged around with it for a while before reading somewhere that it just slides down. I thought I had read that it snapped on, so I had been a little flustered on why it wouldn't snap off.
Anyway, if anyone has suggestions I'd be all ears.
Tim -
It's not to clear but there is a piece of spring steel that rotates away from the main (circuit board side) of the connector....this piece sort of hugs the parameter of the screen cable locking it to the circuit board...both arms wrapped around your brother....looking closely (10x magnifier) at this cable one of the gold connections is slightly oxidized---my display arbitrarily flickers and this symptom is lessened as the temperature increases...I suspect this is the cuase of the screen flashing on/off
brian62 - Contestar
Quite los dos tornillos siguientes que sujetan el soporte del cable de datos de la pantalla a la caja superior: Un tornillo Phillips de 7 mm.
  • Quite los dos tornillos siguientes que sujetan el soporte del cable de datos de la pantalla a la caja superior:
    • Un tornillo Phillips de 7 mm.
    • Un tornillo Phillips de 5 mm.
  • Levante el soporte del cable de datos de la pantalla fuera de la caja superior.
Agregar Comentario
Retire los dos tornillos Torx externos de 6,5 mm que sujetan cada uno de los dos soportes de pantalla a la caja superior (4 tornillos en total). Retire los dos tornillos Torx externos de 6,5 mm que sujetan cada uno de los dos soportes de pantalla a la caja superior (4 tornillos en total).
  • Retire los dos tornillos Torx externos de 6,5 mm que sujetan cada uno de los dos soportes de pantalla a la caja superior (4 tornillos en total).
This says t use a 6.5 mm Torx driver. In the required tools list it only mentions a 6 mm Torx driver. Where can we find a 6.5 mm Torx Driver?
Matthew Shaw - Contestar
The 6mm vs 6.5mm is the length of the screw. It is still a T6 head (although mine was a T7 for some reason). I think the middle screw on each side is 0.5mm longer.
Dean Landry -
lol… turns out mine is a mid-2012 model. That accounts for the different screw head. But the 6mm vs 6.5mm still use the same driver if they’re both T6.
Dean Landry -
In my case, i had to use a t8 screwdriver. My tools are not from Ifixit but i’m just sayin.
Abra su MacBook para que la pantalla sea perpendicular a la mayúscula.
  • Abra su MacBook para que la pantalla sea perpendicular a la mayúscula.
  • Coloque su MacBook abierto en una mesa como se ilustra.
  • Mientras sostiene la pantalla y la mayúscula junto con la mano izquierda, retire el tornillo Torx de 6.5 mm restante del soporte inferior de la pantalla.
Agregar Comentario
Asegúrese de sujetar la pantalla y la mayúscula junto con la mano izquierda. Si no lo hace, la pantalla liberada / mayúscula puede caer, dañando potencialmente cada componente.
  • Asegúrese de sujetar la pantalla y la mayúscula junto con la mano izquierda. Si no lo hace, la pantalla liberada / mayúscula puede caer, dañando potencialmente cada componente.
  • Retire el último tornillo Torx T6 de 6 mm que fija la pantalla en la parte superior.
Agregar Comentario
Coge la parte inferior con la mano derecha y gírala ligeramente hacia la parte superior de la pantalla para que el soporte de la pantalla superior despeje el borde inferior. Gire la pantalla levemente lejos de la parte inferior
  • Coge la parte inferior con la mano derecha y gírala ligeramente hacia la parte superior de la pantalla para que el soporte de la pantalla superior despeje el borde inferior.
  • Gire la pantalla levemente lejos de la parte inferior
Agregar Comentario
Levante la pantalla hacia arriba y lejos de la parte superior, teniendo en cuenta los soportes o cables que pueden quedar atrapados.
  • Levante la pantalla hacia arriba y lejos de la parte superior, teniendo en cuenta los soportes o cables que pueden quedar atrapados.
Re-assembly hint: Laying the base, keyboard down, on a table top with the hinge side over the edge about 1/2" toward you is a more stable position for re-assembly than trying to do this up on its edge. This has the added benefit of being able to reinsert the torn screws vertically.
Pete H - Contestar
May be in the wrong place but then please direct me. At this step, can I just take off the upper half (meaning the screen, LCD, and top housing shell in one) and simply replace it with another upper half of the same edition???
cmackay13stmarys - Contestar
Agarre la cubierta del embrague como se muestra y deslícela hacia el lado derecho de la pantalla. Debería moverse aproximadamente 1/4 &quot;y detenerse. No lo fuerce más allá de este punto.
  • Agarre la cubierta del embrague como se muestra y deslícela hacia el lado derecho de la pantalla.
  • Debería moverse aproximadamente 1/4 "y detenerse. No lo fuerce más allá de este punto.
i've found this impossible to get back on correctly.
i cant get the plastic to slide back that 1/4" it needs to fit properly
Does anyone know any tricks? :(
Ashley Berthon - Contestar
imagine the monitor upside down and the screen facing away from you. You have to put the cover over to the right of where it goes about an inch or 2 and it will go in, then, slide it left to lock it into place
stdonato - Contestar
This is a great guide but it's lacking one thing - where can I get a replacement clutch? I don't have a donor machine available, can I order just the plastic piece somewhere?
Wayne Poole - Contestar
I was replacing a clutch cover that had cracked into a few pieces. I found the replacement didn’t slide to the left on installation. On further investigation I found the tabs from the old one were broken off inside where the cover slides. Once they were removed the install wen much better.
I found my replacement cover on Amazon.ca in case someone needs a Canadian source.
Dean Landry - Contestar
Balancee suavemente la cubierta del embrague hacia adelante y hacia atrás en su eje largo mientras lo retira de la pantalla Haga esta acción a lo largo de la longitud de la tapa del embrague hasta que pueda levantarla del marco y conectarla a la pantalla.
  • Balancee suavemente la cubierta del embrague hacia adelante y hacia atrás en su eje largo mientras lo retira de la pantalla
  • Haga esta acción a lo largo de la longitud de la tapa del embrague hasta que pueda levantarla del marco y conectarla a la pantalla.
Agregar Comentario
Retire la tapa del embrague de la pantalla.
  • Retire la tapa del embrague de la pantalla.
The flat face goes on the bottom edge of the display. The display and wifi cables must be routed below the hinges in the display, that is, closer to the bottom edge of the display.
Robert Rossi - Contestar
This was an easy replacement didn’t need the guide.
Sandy - Contestar
Conclusión
Para volver a armar su dispositivo, siga estas instrucciones en orden inverso.
18 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
For Step 17...if you are going to be touching the hinge screws on the display, you should consider using Loctite on them when you tighten them. I used this guide to tighten mine, but they worked loose again.
richard waters - Contestar
Great guide, no issues at all. I skipped Step 4 (removing subwoofer cable) after reading the comments.
Rachael Burke - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 37
Últimos 30 Días: 130
Todo El Tiempo: 27,662
