Introducción
Use this guide to replace a broken AirPort/Bluetooth board.
Remove the following ten screws:
  • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
Does void the warranty?
jfondeur - Contestar
No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
oakdragon12 - Contestar
How much weight can I save by removing the optical drive?
gunes314 - Contestar
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
Carlos Duarte do Nascimento - Contestar
Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
Seji the veggie -
What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
pmhparis -
The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
Dan -
I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
John Adam Wickliffe - Contestar
Hey guys,
this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
I posted some pictures on your facebook page..
renatumb - Contestar
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - Contestar
Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
kschmesk - Contestar
I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
Alex - Contestar
The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
. Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
I got round it by using the camera cable from the old set and cutting off the new one
brian whittle - Contestar
Hello MacWorld,
Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
wer 10/5/15
tayseer999 - Contestar
I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
GotMac - Contestar
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - Contestar
on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
Maximilian Klotz - Contestar
I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
gilded yak - Contestar
Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
Jack - Contestar
I have the same question. What is the difference between shouldered and not? So hard to see any difference…
Michael Wilkens -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - Contestar
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
Stephen Smith - Contestar
A screw does not come out, how can I get it out? Many thanks in advance for your help
Wilder Torres - Contestar
Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
airshack - Contestar
when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
Matt - Contestar
It seems to me the yellow and orange screws are the same
Luca Giancarli - Contestar
The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
Don Cely - Contestar
Two screw types:
______________________________
Shouldered Unshouldered
xxxxxxx……….xxxxxxx
..xxxxx……..….…….x…….
…..x……..…...……….x…….
…..x…………....……..x…….
El Crashitan - Contestar
Use your fingers to pry the lower case away from the body of the MacBook near the vent. Remove the lower case.
  • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
  • Remove the lower case.
If the black vent window that is attached to the back cover becomes loose what kind of glue should be used to attach it again, thermal paste or super glue?
Thanks for your help.
Mikell - Contestar
bonjour cette truc ça marche au mac Brook pro Retina ou pas?
Shi Feng - Contestar
Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
Claire Rapp -
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board. It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
Is this step of removing the battery connector required?
manodh - Contestar
yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
khull -
Sooo the track pad is under the battery...you kind of have to remove it to get to the track pad.
stiknrudder -
This step is not really required. Apple does not recommend it.
Steven Layton - Contestar
My Battery does not get recognized after i disconnected it, screw this site!
Diego Hernandes -
Did you properly ground yourself to the case before putting the spudger to the connector/logic board? Did you use a spudger or something else that is non conductive...or did you use a flat blade metal screw driver instead and compound your error by not grounding yourself before touching the logic board? All kinds of variables here but the bottom line is iFixit provided you a guide to fix your computer. Lots of others have followed this guide without trouble. Your battery issues are not their fault. They did say this guide was moderate difficulty...maybe it's just a little beyond your skill level. We should all know our limits!
stiknrudder -
Rather than be careful of the corners of the connector i would say don't use the spudger anywhere near the corners. While the corner looks like the obvious place to begin to pry it up from, it will break. Levering from the sides as the instructions suggest works well.
ausmkv - Contestar
wonder why apple does not recommend it?!
Peter - Contestar
I would recommend it, one careless short and the whole board is dead......
John - Contestar
simply remove the battery rather than disconnecting the cable
toiu - Contestar
What do you mean by "remove the battery"?
Anrothan -
Don't know what the deal is with the battery, but this IS a necessary step to keep from frying the logic Board if you accidentally touch something and short it out. I did this step every time during my troubleshooting and The battery was ALWAYS recognized by the system the next time I turned the MBP on. So be safe and don't fry your logic board in the process...
fasthans - Contestar
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
aekinaka - Contestar
Installed/upgraded 4gb RAM to the system maximum 16gb and installed a 500 gb SSD today....DID NOT disconnect the battery cable....no issues at all when I powered back up. Then did a clean install of OSX Yosemite....next I used a time machine backup to put all my stuff back on the new HD. From start to finish it took about 4 hours. Macbook boots up right at 16 seconds now.
MacProUser - Contestar
Easiest to use two spudgers, one on each short end, I found.
Simon Mundy - Contestar
I took off th Airport /Bluetooth connectors but the number J3 connector is broken and so where can i buy J3 connecter for the Airport/bluetooth board
Zeerachen - Contestar
Its a lot easier and safer (corner wise) to pry it using the flat side of the black spudger directly in front of the connector (don't go/use the corners) very easily you will be able to pry it further by inserting the spudger into a better and thicker plastic section of the connector
Ed Oliver - Contestar
DON'T remove the Battery Cable, you risk the battery NOT being recognised when you start the Mac up again, or breaking it!! More to the point, APPLE DOES NOT RECOMMEND THIS, so don't do it! I Installed 2x 8GB ( 16Gb total) of Crucial Mac RAM at 1333Mhz for my Late 2011 MacBook Pro, and it works beautifully, fully recognised and working well. I followed these instructions, but as Apple didnt recommend disconnecting the battery, I skipped this step, and as well as taking less time, nothing was damaged or broken, and everything works perfectly!!! Just make sure that you DISCHARGE ALL STATIC ELECTRICITY FROM YOUR HANDS, by touching a metal surface in the Mac. Apple recommends the edge of the Optical Disk Drive ( Big silver thing ) before touching any parts. Also, Take care removing the RAM out of its packet, DO NOT touch the Gold connectors, and hold the RAM by the edges. Finally, be PATIENT, GENTLE and it should all go perfectly. I managed it first time, with no technical ability, so follow my advice. Good luck!
Bradley Marks - Contestar
Followed the tuto Step by step. Disconnected the battery (quite easily).
No problem when I lit the Mac on again. Battery's here, date's right.
nichoferr - Contestar
Switch off your Mac and continue without disconnecting the battery. Don't know how it will switch on by itself.
Mfernandez - Contestar
This comment made me think that disconnecting the battery was no point at all, because really - how would the computer be able to switch on by it self. So... I had my mac flipped around and was fiddling with the last part of the guide when I all of a sudden hear the start up sound! Don't know how and why it did. I turned it around with it guts open and guts hanging out. Screen was on. I forced it to shut down by keeping the power button down. Turned it back and first thing removed the battery cord.
Luckily the computer started up just like normal. But hearing that sound was just too scary.
BTW I had been cautious to de static myself multiple times.
wassberg -
Definitely do this step. It's an easy disconnect anyway and also easy to reconnect later.
I removed the battery cable for the repair. When I plugged in the MagSafe adapter after the repair, the Mac turned on automatically without pressing the power button and I was a bit worried, but after a restart everything worked fine again. I did have to reset date and time in Preferences. The battery was recognized OK.
Raymond Rinaldi - Contestar
Okey, I skipped this battery disconnection part. Did not do anything like this before in my life, changing the cable was super easy!
Marijke de Vries - Contestar
The official Apple guide to replacing the RAM says nothing about disconnecting the battery but it does recommend touching metal inside to discharge static. https://support.apple.com/en-us/HT201165
B T - Contestar
I always do this when working on MacBooks (over ten years) and it never caused an issue. Don’t worry about this step as removal of the battery connector is simple. This particular connector is pretty much goof-proof as it won’t break. I’m fairly aggressive and just pop it off whenever I’m working on the Macbook Pro.
Hello!
Do I really need to use a spudger tool? Can’t I just use like two plectrums for guitar? xD
Myzcio - Contestar
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
What are the changes of it broke when i bend it?, after i disconect it does not work anymore
Diego Hernandes - Contestar
The guide worked perfectly, as it has in the past (our family has three Mid-2012 Macbook Pros that have been separately upgraded with RAM and SSD).
The PH00 screwdriver fit perfectly.
One note on getting the screws to seat easily and thread perfectly...always turn them gently a couple turns to the left (CCW or Anti-Clockwise) until you hear a small click. That's where the threads will grab. Works with any screw, but when threads are fine, this will help ensure that the screw is at the correct angle and will grab and seat perfectly.
Great guides. Thanks!
timgunkel - Contestar
Got RAM in but only one slot is working and now I can't remove! The RAM won't pop up like before and tabs don't seem to do anything. Please advise.
Sal Ergrapes - Contestar
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Followed the advice and right as I was installing the replacement fan , the socket broke right off the motherboard.
Ian Thal - Contestar
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
lelandjordon - Contestar
does the battery connection need to be removed? I only ask as other videos etc have not shown this step.
Darren Rose - Contestar
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
Greg - Contestar
Carefully pull the camera cable out of its socket on the logic board.
  • Carefully pull the camera cable out of its socket on the logic board.
  • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
I ripped the camera cable where can I buy a new one
fadybitar2000 - Contestar
Be very careful at step 6!
I had the same problem with the model "Late 2011" and I doubt to step 6 because the camera cabel connector was plugged very tight in the board-socket. So I cannot believe it is so easy to unplug the connector.
I bought a new camera cable on eBay.
Tomasz Borkowski - Contestar
Be extremely careful on step 6 with late 2011 model unibody macbooks! The cable is connected very tightly to the board and has a great chance of ripping if you just pull the cable.
Tim Rauls - Contestar
I ripped the camrea cable socket on the logic board.
Pedram Fattahi - Contestar
Walk the cable out with a spudger!!! The Retina 2012 guide has this and this was so easy using the tool.
Robert Le Monds - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket. De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
  • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
What adhesive is suitable for reattaching the foam tape and wires that were removed from their normal routing?
David Warshowsky - Contestar
I want to know that too!
Alberto Harres Rocha -
Take a few phone close-ups of this corner of your system prior to disassembly. Extra photos really help during reassembly.
I didn’t use any extra adhesive here during reassembly. The camera cable fits snuggly between the subwoofer module and the DVD drive. Apple’s adhesive here is really just overkill.
Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board. De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
  • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
Can someone explain me what this "antenna cable" is for? I changed my Topcase and this antenna did break during the procedure =(.
The problem is i can't find this cable anywhere to buy and i don't even know his function. WIFI and Bluetooth are working just fine.
Can someone please help me?
kadiroeztel - Contestar
Same here, I was removing the display and once i put it back on the three little antenna cables fall off. Any idea how to replace it or find it?
Hector Torres -
Those are the WiFi antennae..
auadix -
When I was repairing the hinge of my laptop two of the antenna cable connectors came off the ends of the antenna wires. Can someone confirm what these are called and the size so I can source replacements? I believe they may be called ’Micro RF Coax Connector’ but I am not sure what size I need. For the record the wifi is actually still working but may be a bit slower than normal. Thanks for your help.
Alan Holt - Contestar
Using the method described in the last step, disconnect the remaining three antenna connectors. De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
  • Using the method described in the last step, disconnect the remaining three antenna connectors.
  • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
What are these? Like in order? I broke the middle one and am trying to find a replacement. The mac actually functions quite normally, currently using it to type this ahaha, anyways, only difference I've noticed is that the speaker sounds a bit weird/off. Internet is fine, display is fine, everything is fine at the moment besides the speaker. And in case you're wondering how exactly broken it is, its not connected to begin with since it ripped ahahaa...
Lupita Felix - Contestar
Remove the following five screws:
  • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
The two screws marked in orange are not present in my early 2011 macbook pro
bhavishya tyagi - Contestar
Should be worth noting that the black tape/wire grommet on the right red screw is flimsy. When overtightened, it can tear.
Brad Stossel - Contestar
Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
Agregar Comentario
Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
  • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
Agregar Comentario
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
  • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
Agregar Comentario
Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board. Remove the AirPort/Bluetooth cable.
  • Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
  • Remove the AirPort/Bluetooth cable.
Agregar Comentario
Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
  • Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
Agregar Comentario
Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
  • Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
Agregar Comentario
Remove the AirPort/Bluetooth board from its bracket.
  • Remove the AirPort/Bluetooth board from its bracket.
  • Be careful not to damage the pink thermal pad attached to the bracket.
I did the whole thing and my new AirPort isnt working.. i checked twice the cables and nothing yet.. does anyone know if i need to download something to make the mac recognize my AirPort? - the bluetooth is working in both boards (the old one and the new one).. any clues to help me out here?
paulofjunior - Contestar
Any idea what was wrong with your computer. I'm in the exact same situation.
goreds6 -
I accidentally pried the soldered connector off the board (the j3 bt connector) as I have seen this connector is only two/ three channel. Is it an option to try to solder back the connection? Thanks for all of your help Ifixit!!
skogliruben2 - Contestar
I did the same thing as skogliruben2. the J3 bt connect popped right off with the antenna cable when I tried to pry it off. I'd also like to know if I can try soldering it on. I really can't even disconnect the little connecter from the cable socket now. What does this antenna do? Thanks for your help!
maryetna - Contestar
Conclusión
75 personas más completaron esta guía.
Great tutorial. Unfortunately I booted back up and my Bluetooth is no longer working. Has anyone else experienced this issue? Is there some sort of reset that can be done to "recognize" the new card? I'm still able to turn Bluetooth on and off from system preferences but my apple keyboard and mouse do not connect. Thanks for any insights :)
Sean - Contestar
If you change your bluetooth card, its MAC address will change. Since pairing is done by MAC, you will need to re-pair all devices.
Oliver Humpage - Contestar
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable. Lesson learned: try the cheaper part first! Not a total loss, now I have Bluetooth 4.
Michael Schwern - Contestar
Does the wifi/bluetooth ribbon cable have some kind of glue? Mine is flyaway, so i don't know if it's ok to just put tape over connector or do i need glue? Thanks and sorry for my bad english... Obrigado
Javier Lara - Contestar
Any ideas if this is the same process for the 13” Mid-2010 model? I can't find a guide to replace the bluetooth card on this model.
Thanks!
dcp000 - Contestar
Hello,
I was able to complete this repair in less than 40 minutes, thanks to the author and his easy-to-follow guide!
Regarding Step 10 - I found it easier to use a Phillips #000 screwdriver (instead of the recommended #00 size) for the two “orange” 3.1 mm Phillips screws, as it did not slide off the tiny screw heads like the larger-sized screwdriver would.
Robert Sebastian Soyka - Contestar
I am looking to do this on an early 2011 macbook pro 13” and a lot of places speak about having to modify files in order to get bluetooth 4.0 working. I would like to have full continuity and hand-off working. Will a simple swap using this card enable this or will I need to root around in folders etc?
Any advice would be appreciated!
Prajay - Contestar
I did that a couple of years ago, but suddenly airdrop stop working. I’m not sure if there’s an issue with the software or the hardware. Is there any aditional patch that we need to run with any other update? Can someone please help
sergiobe87 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 16
Últimos 7 Días: 142
Últimos 30 Días: 708
Todo El Tiempo: 89,238
