Introducción
Use this guide to replace the AirPort board.
Qué necesitas
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
7 personas más completaron esta guía.
