Saltar al contenido principal
MacBook Core 2 Duo Memory Cover Replacement
Qué necesitas
  1. MacBook Core 2 Duo Memory Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Memory Cover Replacement: paso 2, imagen 1 de 1
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Memory Cover Replacement, Memory Cover: paso 3, imagen 1 de 1
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. MacBook Core 2 Duo Memory Cover Replacement: paso 4, imagen 1 de 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
Conclusión
54 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 34,242
