Introducción
How to reach the logic board.
Qué necesitas
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Disconnect the MagSafe board cable from the logic board by pulling the snap-in connector out (to the right).
5 personas más completaron esta guía.
