Introducción
Restore sound to your laptop by replacing the speaker.
Unplug your MacBook Air and power it off before you proceed.
  • Unplug your MacBook Air and power it off before you proceed.
  • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
Agregar Comentario
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Agregar Comentario
Disconnect the battery connector by pulling it straight out of its socket.
  • Disconnect the battery connector by pulling it straight out of its socket.
Agregar Comentario
Remove the following nine screws securing the battery to the Air:
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Lift the battery out of the Air.
  • Lift the battery out of the Air.
Agregar Comentario
Remove the following two screws securing the speaker assembly to the upper case.
  • Remove the following two screws securing the speaker assembly to the upper case.
    • One 3 mm Phillips.
    • One 5.8 mm Phillips.
Agregar Comentario
Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket. Disconnect the audio out connector from its socket.
  • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
  • Disconnect the audio out connector from its socket.
Agregar Comentario
Rotate the speaker assembly toward the center of the Air. Use a spudger to pry the speaker cable connector up off the audio board.
  • Rotate the speaker assembly toward the center of the Air.
  • Use a spudger to pry the speaker cable connector up off the audio board.
Agregar Comentario
Use the tip of a spudger to pry the speaker connector up off the audio board.
  • Use the tip of a spudger to pry the speaker connector up off the audio board.
Agregar Comentario
Use the tip of a spudger to separate the audio board from the adhesive securing it to the logic board.
  • Use the tip of a spudger to separate the audio board from the adhesive securing it to the logic board.
Agregar Comentario
Disconnect the audio-out cable by pulling the male end straight away from its socket on the audio board.
  • Disconnect the audio-out cable by pulling the male end straight away from its socket on the audio board.
Agregar Comentario
Speaker assembly remains.
  • Speaker assembly remains.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 18
Últimos 30 Días: 74
Todo El Tiempo: 18,721
