Introducción
Your Air is thirsty! Keep those electrons flowing and fix your broken DC-In board.
Unplug your MacBook Air and power it off before you proceed.
  • Unplug your MacBook Air and power it off before you proceed.
  • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
Agregar Comentario
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Agregar Comentario
Disconnect the battery connector by pulling it straight out of its socket.
  • Disconnect the battery connector by pulling it straight out of its socket.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the following nine screws securing the battery to the Air:
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
Agregar Comentario
Lift the battery out of the Air.
  • Lift the battery out of the Air.
Agregar Comentario
Remove the single Phillips screw securing the display data cable ground loop to the upper case.
  • Remove the single Phillips screw securing the display data cable ground loop to the upper case.
Agregar Comentario
Lift the display data cable slightly for enough clearance to remove the two Phillips screws securing the DC-In board to the upper case. Lift the DC-In board slightly and pull its connector straight away from the socket on the logic board.
  • Lift the display data cable slightly for enough clearance to remove the two Phillips screws securing the DC-In board to the upper case.
  • Lift the DC-In board slightly and pull its connector straight away from the socket on the logic board.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 11
Últimos 30 Días: 58
Todo El Tiempo: 13,808
