Saltar al contenido principal
MacBook Air 13" Mid 2013 I/O Board Replacement
Qué necesitas
  1. MacBook Air 13" Mid 2013 I/O Board Replacement, Lower Case: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2013 I/O Board Replacement, Battery Connector: paso 3, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement, Battery Connector: paso 3, imagen 2 de 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Mid 2013 I/O Board Replacement, I/O Board Cable: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  5. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 5, imagen 1 de 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  6. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 6, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement: paso 6, imagen 2 de 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  7. MacBook Air 13" Mid 2013 I/O Board Replacement, Fan: paso 7, imagen 1 de 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 8, imagen 1 de 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  9. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 9, imagen 1 de 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  10. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 10, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement: paso 10, imagen 2 de 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
  11. MacBook Air 13" Mid 2013 I/O Board Replacement, I/O Board: paso 11, imagen 1 de 1
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  12. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 12, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement: paso 12, imagen 2 de 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  13. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 13, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement: paso 13, imagen 2 de 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
  14. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 14, imagen 1 de 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  15. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 15, imagen 1 de 2 MacBook Air 13" Mid 2013 I/O Board Replacement: paso 15, imagen 2 de 2
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
  16. MacBook Air 13" Mid 2013 I/O Board Replacement: paso 16, imagen 1 de 1
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
Conclusión
45 personas más completaron esta guía.
8 comentarios
How can I tell if its my I/O board that is damaged? I cannot hear sound from Aux port or from the speakers on my macbook. Laptop still charges fine though.
Ralphy Sierra - Contestar
Check to see if your USB port on that side works. That was how I know mine was bad.
craig - Contestar
Was easier than I thought to do.
craig - Contestar
If light on magsafe doesn't turn on, is it safe to say the io board needs to be replaced?
Jon Lewin - Contestar
Thumbs up Walter!
jlaramore - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 84
Todo El Tiempo: 29,751
