Introducción
Use this guide to replace your Air's solid state hard drive.
  • Before proceeding, power down your machine. Close the display and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm P5 Pentalobe screws
    • Eight 2.6 mm P5 Pentalobe screws
  • The special screwdriver needed to remove the ten 5-point Pentalobe screws can be found here.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Contestar
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Contestar
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Contestar
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Contestar
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Contestar
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Contestar
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Contestar
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Contestar
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Contestar
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Contestar
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Contestar
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board. Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
The clear plastic tab is missing on mine. Whoever worked on my laptop before me seems to have ripped it off. Now what?
mjmorawski - Contestar
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Agregar Comentario
To avoid damaging its socket, do not lift the end of the SSD excessively. Slightly lift up the end of the SSD and pull it straight out of its socket on the logic board.
  • To avoid damaging its socket, do not lift the end of the SSD excessively.
  • Slightly lift up the end of the SSD and pull it straight out of its socket on the logic board.
  • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Agregar Comentario
Linea de Meta
61 personas más completaron esta guía.
If I replace the SSD with another one purchased from iFixit, will it appear as an external or internal drive?
At my job, it's standard to encrypt drives. I purchased an SSD from another vendor and because it showed as external, couldn't be encrypted. I just want to avoid this problem before purchasing one from here.
flux1968 - Contestar
Muito bom o roteiro, deu certinho.
ahdesiqueira - Contestar
This should really be rated as easy. Took less than 5 minutes thanks to this excellent guide.
Tyler Berry - Contestar
Absolutely spot on. Thanks Andrew! The only potential pitfall in this job is getting the right replacement SSD (or, if you're extracting the SSD to use elsewhere, getting the right caddy.)
Ben Godwin - Contestar
anybody knows if exist any hdd to replace the ssd?
I have a mb air 13 mid 2011 in my hands and it has behaviour a mac(/pc) with a hdd damaged? same noise, same latencies, same way to damage files…
and over the top “informations about this mac” says it is a macbook pro 13
never seen in my life…
smoker_man2004 - Contestar
This was really easy! I removed the hard drive from my mid 2011 MacBook Air and placed it in a free standing caddy - no problem. But it appears that the disk is empty. Is that what it would look like if the hard drive was ruined? (I was told the hard drive was fine - it was my logic board that was fried. So I’m trying to retrieve my data.) Or do I have it inserted wrong? Or… any other explanation?
Tammie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 32
Últimos 7 Días: 157
Últimos 30 Días: 721
Todo El Tiempo: 134,202
