Introducción
Use this guide to replace your AirPort/Bluetooth card.
Resumen del Video
  • Before proceeding, close your computer and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
Agregar Comentario
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
Agregar Comentario
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
Agregar Comentario
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Agregar Comentario
Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board. Remove the AirPort/Bluetooth board from the Air.
  • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
  • Remove the AirPort/Bluetooth board from the Air.
Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Which UFL plug is the WIFI one? the one closer to the screw or the other one?
-Majh0l@hush.com
uxa1 - Contestar
Dear:
I bought a new A1369 AirPort/Bluetooth Board.When I installing it, I accidentally broken the cable that you were prying at step 4, What can I do?
THx!
Alex - Contestar
Which antenna connector is The wi-fi one? The one closest to the screw or the one furthest away?
Joel S - Contestar
I would like AC WiFi and Bluetooth 4 support by upgrading the internal card. Can you install upgrade WiFi/Bluetooth cards into this slot?
David Jones - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 16
Últimos 30 Días: 68
Todo El Tiempo: 24,931
