Introducción
Use this guide to replace a damaged I/O board ribbon cable.
Qué necesitas
Herramienta utilizada en este paso:P5 Pentalobe Screwdriver Retina MacBook Pro and Air
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
4 personas más completaron esta guía.
