Saltar al contenido principal
MSI GE62 Apache Pro 004 Speakers Replacement
Qué necesitas
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: paso 2, imagen 1 de 2 MSI GE62 Apache Pro 004 Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: paso 3, imagen 1 de 3 MSI GE62 Apache Pro 004 Speakers Replacement: paso 3, imagen 2 de 3 MSI GE62 Apache Pro 004 Speakers Replacement: paso 3, imagen 3 de 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: paso 4, imagen 1 de 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: paso 4, imagen 2 de 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: paso 4, imagen 3 de 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: paso 5, imagen 1 de 2 MSI GE62 Apache Pro 004 Speakers Replacement: paso 5, imagen 2 de 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Conclusión
Majid Al Hashmi
Miembro Desde 02/13/18
283 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S15-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 1,491
