Saltar al contenido principal
MSI GE62 6QF Apache Pro Battery Replacement
Qué necesitas
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: paso 2, imagen 1 de 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: paso 3, imagen 1 de 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: paso 4, imagen 1 de 3 MSI GE62 6QF Apache Pro Battery Replacement: paso 4, imagen 2 de 3 MSI GE62 6QF Apache Pro Battery Replacement: paso 4, imagen 3 de 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: paso 5, imagen 1 de 2 MSI GE62 6QF Apache Pro Battery Replacement: paso 5, imagen 2 de 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: paso 6, imagen 1 de 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: paso 6, imagen 2 de 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
Conclusión
4 personas más completaron esta guía.
Justice Owens
Miembro Desde 09/26/17
604 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G3, Passmore Fall 2017 Miembro de USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Miembros
5 Guías creadas
Un comentario
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 6,245
