Introducción
This guide will show how to lubricate the power dial. Your power dial will operate smooth after completing this guide.
Unplug the device before proceeding. Remove the phone cord from the phone jack from the base of the headset.
  • Unplug the device before proceeding.
  • Remove the phone cord from the phone jack from the base of the headset.
    • Use a plastic opening tool to remove the phone cord.
Agregar Comentario
Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
  • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
  • Remove the cord from the phone base.
Agregar Comentario
Use finger to remove the battery cover. Use finger to remove the battery cover.
  • Use finger to remove the battery cover.
Agregar Comentario
Remove the Volume Dial by gently grasping the dial and pulling away from the base. Remove the Volume Dial by gently grasping the dial and pulling away from the base.
  • Remove the Volume Dial by gently grasping the dial and pulling away from the base.
Agregar Comentario
Remove the 6 screws from the base shell.
  • Remove the 6 screws from the base shell.
    • Remove the 3 12mm screws with the Philips head #1 screw driver.
    • Remove the 3 18mm screws with the Philips head #1 screw driver.
Agregar Comentario
Pry off the base shell using a Plastic Opener Tool. Pry off the base shell using a Plastic Opener Tool.
  • Pry off the base shell using a Plastic Opener Tool.
Agregar Comentario
Inside base shell on circuit board, lubricate power switch.
  • Inside base shell on circuit board, lubricate power switch.
  • CAUTION: Make sure lubricant does not circuit board. This can damage the circuit board.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 6
Todo El Tiempo: 602
