Saltar al contenido principal
Logitech UE MegaBoom Battery Replacement
Qué necesitas
  1. Logitech UE MegaBoom Battery Replacement, Outer Mesh: paso 1, imagen 1 de 3 Logitech UE MegaBoom Battery Replacement, Outer Mesh: paso 1, imagen 2 de 3 Logitech UE MegaBoom Battery Replacement, Outer Mesh: paso 1, imagen 3 de 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Battery Replacement: paso 2, imagen 1 de 3 Logitech UE MegaBoom Battery Replacement: paso 2, imagen 2 de 3 Logitech UE MegaBoom Battery Replacement: paso 2, imagen 3 de 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Battery Replacement: paso 3, imagen 1 de 2 Logitech UE MegaBoom Battery Replacement: paso 3, imagen 2 de 2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
Conclusión
14 personas más completaron esta guía.
Oscar Ambriz
Miembro Desde 09/27/17
958 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S9-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Miembros
14 Guías creadas
24 comentarios
There is a way to take it apart without all these steps and a complete tear down.
Brian Longhurst - Contestar
How to ensure it’s waterproof upon reassembly?
mdeblasi - Contestar
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
coryjohnson011 - Contestar
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
sizz0p - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 165
Ultimos 30 días: 811
Todo El Tiempo: 47,974
