Introducción
You will learn how to remove and install the support spring.
Partes
No se requieren partes.
Hold the mouse in your hand so that the bottom side is facing upward.
  • Hold the mouse in your hand so that the bottom side is facing upward.
  • Locate the #1 screw towards the bottom half of the mouse.
  • Take the 4.76 mm Phillips screwdriver and unscrew the #1 screw that was previously located.
باز کردن پیچ زیر موس
h sh - Contestar
Place the mouse back on the hard surface, with the bottom side touching the hard surface. Gently, lift up the top cover of the mouse and remove.
  • Place the mouse back on the hard surface, with the bottom side touching the hard surface.
  • Gently, lift up the top cover of the mouse and remove.
جدا کردن قاب رو و زیر موس
h sh - Contestar
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up to remove the scroll wheel from the mouse.
  • Locate the scroll wheel on the mouse.
  • Grab the scroll wheel with your thumb and index finger.
  • Gently lift up to remove the scroll wheel from the mouse.
خارج کردن چرخ اسکرول موس
h sh - Contestar
Locate the spring on the scroll wheel. The spring looks like a small, metal piece of wire, coiled up in the middle. Very carefully, remove the spring from the wheel scroll.
  • Locate the spring on the scroll wheel. The spring looks like a small, metal piece of wire, coiled up in the middle.
  • Very carefully, remove the spring from the wheel scroll.
نحوه قرارگیری فنر سمت راست چرخ اسکرول
h sh - Contestar
Replace the spring making sure it is placed on the right side of the wheel with the prongs pointing down. The right side is the side without the black plastic square as shown in the photos.
  • Replace the spring making sure it is placed on the right side of the wheel with the prongs pointing down.
  • The right side is the side without the black plastic square as shown in the photos.
h sh - Contestar
Conclusión
4 personas más completaron esta guía.
Conor Whatley
Miembro Desde 11/01/13
276 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-14, Forte Winter 2013 Miembro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 47
Todo El Tiempo: 1,978
