Introducción
If the microphone in your Logitech G733 Wireless Headset is no longer working and you suspect the microphone jack needs to be replaced, you can replace it with this guide. Since getting to the microphone jack requires taking off the circuit board, you can also access many other components with these same steps. For this guide, you will need a Phillips #000 screwdriver, a Torx T4 screwdriver, and soldering equipment. This is a difficult replacement. Soldering experience is advised.
Qué necesitas
Gently pull the left ear pad off, starting from the top.
Slide your finger around the edges until it releases completely.
Remove the ear pad.
Identify the headphone jack and unsolder all six pins. Using the soldering iron, apply heat to three pins on one side and wiggle the jack free from the melted pool of solder. Repeat for the opposite side.
Use the soldering iron again to solder the new microphone jack back to in its spot.
