Introducción
Remove the top cover of the optical drive to access the internals and replace any malfunctioning components.
Insert an open paper clip into the small hole on the left side of the faceplate. The tray should click open, extend it fully.
  • Insert an open paper clip into the small hole on the left side of the faceplate.
  • The tray should click open, extend it fully.
Agregar Comentario
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Agregar Comentario
Pull the faceplate away from the main chassis.
  • Pull the faceplate away from the main chassis.
Agregar Comentario
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Agregar Comentario
Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
  • Lift the top and bottom chassis straight up in order to remove them.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
James Biggs
Miembro Desde 12/10/11
596 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-5, Regan Fall 2011 Miembro de Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,308
