Turn the router over so that all four of its feet are facing upwards.
  • Turn the router over so that all four of its feet are facing upwards.
Agregar Comentario
Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Agregar Comentario
Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
Agregar Comentario
Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Agregar Comentario
Slide the board unit out and up.
  • Slide the board unit out and up.
Agregar Comentario
Flip the  circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
  • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
  • Slide the back cover out and away from the circuit board.
Agregar Comentario
Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
  • Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
  • Once you complete this step, your router will be completely disassembled.
Agregar Comentario
Conclusión
Allian Roman
Miembro Desde 12/10/11
248 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-4, Regan Fall 2011 Miembro de Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,184
