Introducción
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
Partes
No se requieren partes.
Power down and unplug the device.
  • Power down and unplug the device.
Agregar Comentario
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of      Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Agregar Comentario
Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
Agregar Comentario
Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
Agregar Comentario
To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
  • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
  • This may require a bit of force.
Agregar Comentario
Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
Agregar Comentario
Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts. Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
Agregar Comentario
From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes. Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
  • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
  • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
  • Once the top panel is removed the main board will still be attached to the bottom panel.
Agregar Comentario
Unscrew the two screws that connect the motherboard to the bottom casing. The motherboard and bottom casing should be completely separated at this point.  This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
  • Unscrew the two screws that connect the motherboard to the bottom casing.
  • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
Agregar Comentario
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
  • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
  • For help with soldering or desoldering refer to ifixit's soldering guide: Cómo soldar y desoldar conexiones
Agregar Comentario
Place new LED lights through holes created by desoldering and removing old lights.
  • Place new LED lights through holes created by desoldering and removing old lights.
Agregar Comentario
Solder the lights onto the bottom of the board to solidify the connection and make electrical contact. Follow the Installing the Casing guide in reverse to re-assemble your device.
  • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
  • Follow the Installing the Casing guide in reverse to re-assemble your device.
Agregar Comentario
Conclusión
Once the soldering is complete, the device should work and the LED lights should light up.
Una persona más ha completado esta guía.
Derek Myers
Miembro Desde 04/10/11
243 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-21, Maness Fall 2011 Miembro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,733
