Introducción
If the router isn't working and it is established that the antennas are defective this is the guide for you.
Make sure the antennas are in a straight position, not bent, to remove the black casing. Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  • Make sure the antennas are in a straight position, not bent, to remove the black casing.
  • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
Agregar Comentario
Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
Agregar Comentario
Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
Agregar Comentario
Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
  • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
  • Repeat these steps for other antenna.
Agregar Comentario
Conclusión
After the repairs are made the device should working.
2 personas más completaron esta guía.
Derek Myers
Miembro Desde 04/10/11
243 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-21, Maness Fall 2011 Miembro de Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 2,031
