Saltar al contenido principal
Lenovo Yoga 920-13IKB Screen Replacement
Qué necesitas
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: paso 1, imagen 1 de 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: paso 1, imagen 2 de 3 Lenovo Yoga 920-13IKB Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: paso 2, imagen 1 de 3 Lenovo Yoga 920-13IKB Screen Replacement: paso 2, imagen 2 de 3 Lenovo Yoga 920-13IKB Screen Replacement: paso 2, imagen 3 de 3
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: paso 3, imagen 1 de 2 Lenovo Yoga 920-13IKB Screen Replacement: paso 3, imagen 2 de 2
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: paso 4, imagen 1 de 3 Lenovo Yoga 920-13IKB Screen Replacement: paso 4, imagen 2 de 3 Lenovo Yoga 920-13IKB Screen Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: paso 5, imagen 1 de 1
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 920-13IKB Screen Replacement: paso 6, imagen 2 de 2
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: paso 7, imagen 1 de 1
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: paso 8, imagen 1 de 1
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: paso 9, imagen 1 de 1
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: paso 10, imagen 1 de 1
  11. Lenovo Yoga 920-13IKB Screen Replacement: paso 11, imagen 1 de 1
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: paso 12, imagen 1 de 1
    • Remove the ribbon cable from the connector to detach the screen from the device.
Conclusión
Una persona más ha completado esta guía.
Alyssa McCulloch
Miembro Desde 01/24/19
1,921 Reputación
9 Guías creadas
Equipo
Cal Poly, Team S2-G3, White Winter 2019 Miembro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
4 Miembros
29 Guías creadas
5 comentarios
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - Contestar
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - Contestar
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - Contestar
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 5,585
