Saltar al contenido principal
Lenovo Yoga 720-15IKB Wireless Adapter Replacement
Qué necesitas
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: paso 1, imagen 1 de 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: paso 1, imagen 2 de 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: paso 2, imagen 1 de 2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: paso 2, imagen 2 de 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 1 de 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 2 de 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 3 de 3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: paso 4, imagen 1 de 1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: paso 5, imagen 1 de 1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
Conclusión
Equipo
Cal Poly, Team S19-G3, White Winter 2020 Miembro de Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 20
Todo El Tiempo: 739
