Introducción
This guide will outline the proper procedure for removal of the display assembly. Exercise caution while removing and handling the assembly and its components, as they can easily scratch. Remember to turn the laptop off prior to starting.
Qué necesitas
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
Remove the four 2mm screws using the Philips 00 screwdriver.
Remove the 2.5mm screw using the Philips 00 screwdriver.
10 personas más completaron esta guía.
2 comentarios
Thank you. Very useful.
Great guide, but I think you missed the part of removing the fan
