Saltar al contenido principal
Lenovo Yoga 2 11" Battery Replacement
Qué necesitas
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: paso 2, imagen 1 de 1
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: paso 4, imagen 1 de 1
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 2 11" Battery Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: paso 6, imagen 1 de 1
    • Once all of the wires are detached, carefully remove the battery and replace.
Conclusión
12 personas más completaron esta guía.
Abbey Hickmann
Miembro Desde 10/07/15
197 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-3, Maness Fall 2015 Miembro de Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
4 Miembros
5 Guías creadas
4 comentarios
how do I remove unathorized battery error?
Manuel Durugas - Contestar
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Contestar
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Contestar
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 26,588
