Saltar al contenido principal
Lenovo Yoga 2 11" 20428 Battery Replacement
Qué necesitas
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: paso 1, imagen 1 de 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: paso 1, imagen 2 de 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: paso 1, imagen 3 de 3
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: paso 2, imagen 1 de 1
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: paso 3, imagen 1 de 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: paso 3, imagen 2 de 3 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: paso 4, imagen 1 de 1
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: paso 5, imagen 1 de 2 Lenovo Yoga 2 11" 20428 Battery Replacement: paso 5, imagen 2 de 2
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: paso 6, imagen 1 de 2 Lenovo Yoga 2 11" 20428 Battery Replacement: paso 6, imagen 2 de 2
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 682
