Saltar al contenido principal
Lenovo YOGA 730-15IKB RAM Replacement
Qué necesitas
  1. Lenovo YOGA 730-15IKB RAM Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo YOGA 730-15IKB RAM Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB RAM Replacement: paso 2, imagen 1 de 2 Lenovo YOGA 730-15IKB RAM Replacement: paso 2, imagen 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB RAM Replacement: paso 3, imagen 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB RAM Replacement, RAM: paso 4, imagen 1 de 2 Lenovo YOGA 730-15IKB RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Using a plastic opening tool or other non-metal object, pry up the large metal case on the left side of the motherboard.
  5. Lenovo YOGA 730-15IKB RAM Replacement: paso 5, imagen 1 de 1
    • New RAM can be inserted into the slot below the metal cover.
    • Be careful to not touch the pins on the RAM or the slot, as oils from your fingers can damage the sensitive electronic connections between the RAM and the computer.
Conclusión
4 personas más completaron esta guía.
Mathew Shaham
Miembro Desde 01/23/20
566 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S1-G6, White Winter 2020 Miembro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Miembros
27 Guías creadas
8 comentarios
Thank you so much for this guide! Do you have to do anything with the SSD? Some videos about this say you have to change it but don’t go into detail as to why.
Ted Uy - Contestar
I’m glad you found the guide helpful! You should be able to upgrade your RAM without needing to touch the SSD at all (and vice versa). Neither component should have an impact on the other. The videos probably mention the RAM and SSD together because its convenient to do both upgrades at once.
Ellis Ruckman -
What RAM and what amount of memory would be good to increase to this model?
luis manco - Contestar
I installed a Viper Steel 32Gb DDR4 PC4-21300 2666MHz SO-DIMM. My system now registers 40 Gb of RAM at 2400 MHz.
Performance is a huge jump over the 8 Gb I had before. I upgraded the SSD to a WD Black 1Tb , a Intel AX210 wireless card and this memory. This system is a much different system. Very fast windows 11 machine now. It was always a fast system, but its performance is noticeably improved greatly.
George - Contestar
I thought the max the system could be upgraded to was 16 gb, you were able to upgrade to 40? what was the stock ram that came soldered to the system? have one of these laying around at a family members thinking of picking up to upgrade and pass down to a friend.
dale g -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 32
Ultimos 30 días: 193
Todo El Tiempo: 8,585
