Saltar al contenido principal
Lenovo YOGA 730-15IKB Fingerprint Reader Replacement
Qué necesitas
  1. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 2, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 2, imagen 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 3, imagen 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: paso 4, imagen 1 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: paso 4, imagen 2 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 5, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 5, imagen 2 de 2
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 6, imagen 1 de 1
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Left Fan: paso 7, imagen 1 de 1
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  8. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 8, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 8, imagen 2 de 2
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  9. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 9, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 9, imagen 2 de 2
    • Remove two 4mm Phillips #1 screws.
  10. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 10, imagen 1 de 1
    • Pull the fan up and towards the front of the laptop.
  11. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Right Fan: paso 11, imagen 1 de 1
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
  12. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 12, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 12, imagen 2 de 2
  13. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 13, imagen 1 de 1
  14. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: paso 14, imagen 1 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: paso 14, imagen 2 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: paso 14, imagen 3 de 3
    • Remove the fingerprint reader ribbon cable located at the bottom left of the motherboard.
    • Pull up on the black tab on the connector.
    • The ribbon cable should easily pull out of the connector.
  15. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 15, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 15, imagen 2 de 2
    • Remove the three other ribbon cables at the lower edge of the motherboard.
    • For each, lift up the black tab on the connector.
    • The ribbon cables should easily pull out of the connectors.
  16. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 16, imagen 1 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 16, imagen 2 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 16, imagen 3 de 3
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
  17. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 17, imagen 1 de 1
    • Remove the sticky tape from the top of the wireless card.
  18. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 18, imagen 1 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 18, imagen 2 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 18, imagen 3 de 3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  19. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 19, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 19, imagen 2 de 2
    • Pull up on the thick gray display cable near the back of the laptop to disconnect the display.
  20. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 20, imagen 1 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 20, imagen 2 de 3 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 20, imagen 3 de 3
    • The charger port is connected to the computer by a cable at the top left of the motherboard.
    • Disconnect the cable by pulling the bundle of wires firmly toward the back of the laptop.
    • The cable requires some force to remove. Make sure you do not damage the connector or cable.
  21. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 21, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 21, imagen 2 de 2
    • Remove four 4mm Phillips #1 screws.
  22. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 22, imagen 1 de 1
    • Pull the motherboard up out of the laptop chassis.
    • If you are replacing the motherboard, make sure to remove the SSD, wireless card, heat sink, and extra RAM. Transfer these components to the new motherboard.
  23. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Fingerprint Reader: paso 23, imagen 1 de 2 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Fingerprint Reader: paso 23, imagen 2 de 2
    • Remove one 2mm Phillips #1 screw.
  24. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 24, imagen 1 de 1
    • Remove the small metal plate from above the reader.
    • The ribbon should be kept in case the new fingerprint reader doesn't come with a new ribbon to connect it to the motherboard.
  25. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: paso 25, imagen 1 de 1
    • Pull the fingerprint reader up out of the chassis.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S1-G6, White Winter 2020 Miembro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Miembros
27 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 696
