Saltar al contenido principal
Lenovo ThinkPad X390 Yoga Touchpad Replacement
Qué necesitas
  1. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Back Case: paso 1, imagen 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 3, imagen 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Battery: paso 4, imagen 1 de 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 6, imagen 1 de 1
    • Lift the battery out of the laptop by lifting up.
  7. Lenovo ThinkPad X390 Yoga Touchpad Replacement, Touchpad: paso 7, imagen 1 de 1
    • Disconnect the touchpad ribbon connector from the motherboard using the opening tool.
  8. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 8, imagen 1 de 1
    • Remove the four 4 mm screws using the Phillips #1 screwdriver.
  9. Lenovo ThinkPad X390 Yoga Touchpad Replacement: paso 9, imagen 1 de 1
    • Carefully open the laptop and remove the touchpad.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 25
Todo El Tiempo: 668
