Saltar al contenido principal
Lenovo ThinkPad X280 Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X280 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Battery Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X280 Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Battery Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X280 Battery Replacement: paso 3, imagen 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Battery Replacement, Battery: paso 4, imagen 1 de 3 Lenovo ThinkPad X280 Battery Replacement, Battery: paso 4, imagen 2 de 3 Lenovo ThinkPad X280 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
Conclusión
5 personas más completaron esta guía.
Un comentario
but what about the batteries connection to the mobo?
edit: nvm, i assumed it was a cable not just a connector
Matthew Gould - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 63
Ultimos 30 días: 254
Todo El Tiempo: 7,045
