Introducción
If your Lenovo ThinkPad X1 Carbon 7th Generation does not respond when you use the fingerprint scanner, use this repair guide to replace it.
A functional fingerprint scanner allows the user to log into their device or access private information without entering a password or pin. Though it is not required for the laptop to function, it is a feature that provides easy and smooth accessibility to the device.
Make sure to use non-metallic equipment to follow the guide.
Qué necesitas
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
Peel back the black adhesive tape covering the ribbon cable connecting the trackpad and fingerprint scanner to the motherboard.
2 personas más completaron esta guía.
