Saltar al contenido principal
Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: paso 3, imagen 1 de 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: paso 4, imagen 1 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: paso 4, imagen 2 de 3 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement, Fan and Heat Sink: paso 4, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad X1 Carbon 5th Gen Fan and Heat Sink  Replacement: paso 5, imagen 2 de 2
    • Pick up the fan and heat sink and carefully and remove it.
Conclusión
Una persona más ha completado esta guía.
Equipo
Gateway, Team 1-3, Saknee Fall 2021 Miembro de Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 63
Todo El Tiempo: 1,895
