Saltar al contenido principal
Lenovo ThinkPad T470S Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Wi-Fi Card Replacement, Wi-Fi Card: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  3. Lenovo ThinkPad T470S Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 44
Todo El Tiempo: 1,059
