Saltar al contenido principal
Lenovo ThinkPad T460s RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: paso 2, imagen 1 de 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: paso 3, imagen 1 de 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: paso 4, imagen 1 de 3 Lenovo ThinkPad T460s RAM Replacement: paso 4, imagen 2 de 3 Lenovo ThinkPad T460s RAM Replacement: paso 4, imagen 3 de 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: paso 5, imagen 1 de 3 Lenovo ThinkPad T460s RAM Replacement, RAM: paso 5, imagen 2 de 3 Lenovo ThinkPad T460s RAM Replacement, RAM: paso 5, imagen 3 de 3
    • To remove the existing RAM module, pull tabs marked in the red outwards.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 26
Ultimos 30 días: 111
Todo El Tiempo: 4,500
