Saltar al contenido principal
Lenovo ThinkPad T420s Palm Rest Replacement
Qué necesitas
  1. Lenovo ThinkPad T420s Palm Rest Replacement, Keyboard: paso 1, imagen 1 de 2 Lenovo ThinkPad T420s Palm Rest Replacement, Keyboard: paso 1, imagen 2 de 2
    • Flip your laptop over so the bottom is facing up.
    • Remove the memory panel by removing two black 5mm screws using the Phillips #0.
    • Remove the memory panel.
  2. Lenovo ThinkPad T420s Palm Rest Replacement: paso 2, imagen 1 de 1
    • Remove the two 5mm screw using the Phillips #0 screwdriver.
    • Flip the laptop back over and open it.
  3. Lenovo ThinkPad T420s Palm Rest Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T420s Palm Rest Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T420s Palm Rest Replacement: paso 3, imagen 3 de 3
    • Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
    • The best place to push is on the frame of the keyboard by the power button.
    • Using the metal spudger, lift and slide out the keyboard.
    • When lifting the keyboard do not remove it completely because a cable will still be connected to the laptop.
  4. Lenovo ThinkPad T420s Palm Rest Replacement: paso 4, imagen 1 de 1
    • Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
  5. Lenovo ThinkPad T420s Palm Rest Replacement, Palm Rest: paso 5, imagen 1 de 1
    • Remove the additional thirteen 5 mm screws with your Phillips #0 screwdriver.
    • Remove the two 2.5 X 5 mm screws from the back of your laptop.
    • 2.5 X 5 mm screws are slightly larger than the 5 mm screws.
    • Remove the 3 mm screw from the back of the laptop using the same screwdriver.
  6. Lenovo ThinkPad T420s Palm Rest Replacement: paso 6, imagen 1 de 1
    • Disconnect the black and gray antenna cable connectors in the memory panel on the back of the laptop.
    • Remove any plastic wraps on the blue, white, and tan wires.
  7. Lenovo ThinkPad T420s Palm Rest Replacement: paso 7, imagen 1 de 1
    • Flip the laptop back over and pull all the wires from the previous step through to the top side.
  8. Lenovo ThinkPad T420s Palm Rest Replacement: paso 8, imagen 1 de 1
    • Remove the three 5mm screws holding the palm rest casing in place using the Phillips #0.
  9. Lenovo ThinkPad T420s Palm Rest Replacement: paso 9, imagen 1 de 1
    • Unplug the red, white, and blue bunch of wires.
  10. Lenovo ThinkPad T420s Palm Rest Replacement: paso 10, imagen 1 de 1
    • Lift up the black retaining flap holding the purple ribbon cable in place, and carefully slide out the ribbon.
  11. Lenovo ThinkPad T420s Palm Rest Replacement: paso 11, imagen 1 de 1
    • Remove the top casing by lifting up and sliding out.
    • Be careful when sliding the casing out as some of the casing is still underneath the screen; some wiggling may be required, but do not force it.
Conclusión
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-13, Maness Spring 2015 Miembro de Cal Poly, Team 6-13, Maness Spring 2015
CPSU-MANESS-S15S6G13
4 Miembros
5 Guías creadas
6 comentarios
Thanks for putting this together. I had what seemed to be a fault hardware wifi switch on my ThinkPad T420s. I used this guide to take apart the machine. I re-seated the connector next to the hardware wifi switch (and added a e-tape shim to force downward pressure on it when reassembled). After I made this makeshift mod, the wifi is working again.
Thanks
Timothy Beach - Contestar
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - Contestar
You must not know how to read, or you are just stupid. It clearly says that the guide is for the T420s (the smaller model of the T420).
Thinkpad001 -
You must either not know how to read, or you are just stupid. The guide clearly says that it is for the T420s (the smaller model of the T420). Also, you should fix the numerous spelling and grammatical issues in your comment.
Thinkpad001 -
Keith Cloward: the title states that this is for a T420s, NOT a T420.
stan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 12,379
