Saltar al contenido principal
Lenovo ThinkPad T410s Keyboard Replacement
Qué necesitas
  1. Lenovo ThinkPad T410s Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Keyboard Replacement, RAM: paso 2, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement, RAM: paso 2, imagen 2 de 2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Keyboard Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad T410s Keyboard Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad T410s Keyboard Replacement: paso 3, imagen 3 de 3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: paso 4, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Remove the single Phillips #0 screw that secures the hard drive cover.
  5. Lenovo ThinkPad T410s Keyboard Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip the black plastic tab out.
  6. Lenovo ThinkPad T410s Keyboard Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: paso 6, imagen 2 de 2
    • Pull the hard drive out.
  7. Lenovo ThinkPad T410s Keyboard Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove the Flathead 2.5mm screw.
  8. Lenovo ThinkPad T410s Keyboard Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: paso 8, imagen 2 de 2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  9. Lenovo ThinkPad T410s Keyboard Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad T410s Keyboard Replacement: paso 9, imagen 2 de 2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  10. Lenovo ThinkPad T410s Keyboard Replacement: paso 10, imagen 1 de 1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
Conclusión
Blake Wilson
Miembro Desde 02/21/18
117 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 46
Todo El Tiempo: 2,704
