Saltar al contenido principal
Lenovo ThinkPad Edge E470 Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad Edge E470 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Disconnect the power cord from your computer.
  2. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 2, imagen 1 de 3 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 2, imagen 2 de 3 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Restart the computer and press F1 button rapidly to enter BIOS.
    • Select “Config,” then select “Power,” and press Enter.
    • Select “Disable Build-in Battery” and press "Enter."
  3. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Place the laptop upside down to access the back panel.
    • Loosen the three screws on the back panel using a Phillips #00 screwdriver.
    • Remove the back panel.
  4. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery plug.
  5. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Disconnect the SATA cable for the storage drive from the computer.
  6. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Loosen the screw on the storage drive using a Phillips #00 screwdriver.
  7. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the storage drive.
  8. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 8, imagen 1 de 2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Take the storage drive out of the storage drive bracket.
  9. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 9, imagen 1 de 1
    • Disconnect the SATA cable from the storage drive.
  10. Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 10, imagen 1 de 2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: paso 10, imagen 2 de 2
    • Connect the SATA cable to the computer. Remember to push the lip down.
Conclusión
To reassemble your device, follow these instructions in reverse order. Remember to push back the lid on the SATA connector.
2 personas más completaron esta guía.
Jinxiao Zhou
Miembro Desde 05/29/23
208 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 27
Todo El Tiempo: 221
