Saltar al contenido principal
Lenovo N22 Chromebook Battery Replacement
Qué necesitas
  1. Lenovo N22 Chromebook Battery Replacement, Keyboard: paso 1, imagen 1 de 3 Lenovo N22 Chromebook Battery Replacement, Keyboard: paso 1, imagen 2 de 3 Lenovo N22 Chromebook Battery Replacement, Keyboard: paso 1, imagen 3 de 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Battery Replacement: paso 2, imagen 1 de 3 Lenovo N22 Chromebook Battery Replacement: paso 2, imagen 2 de 3 Lenovo N22 Chromebook Battery Replacement: paso 2, imagen 3 de 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Battery Replacement: paso 3, imagen 1 de 2 Lenovo N22 Chromebook Battery Replacement: paso 3, imagen 2 de 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Battery Replacement: paso 4, imagen 1 de 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Battery Replacement, Battery: paso 5, imagen 1 de 2 Lenovo N22 Chromebook Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Battery Replacement: paso 6, imagen 1 de 2 Lenovo N22 Chromebook Battery Replacement: paso 6, imagen 2 de 2
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Battery Replacement: paso 7, imagen 1 de 2 Lenovo N22 Chromebook Battery Replacement: paso 7, imagen 2 de 2
    • Lift up on the tabs that were held down by the screws to remove the battery.
Conclusión
10 personas más completaron esta guía.
Kevin Yerina
Miembro Desde 04/26/17
453 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S21-G1, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Miembros
14 Guías creadas
4 comentarios
amazing!! thank you
Mark safoo - Contestar
thanks I needed to take the bottom off so I can take a certain screw
xian panadero - Contestar
That's way too much just to take the battery out. it was helpful having these steps. Thank you
Becky Breneman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 52
Todo El Tiempo: 16,665
