Saltar al contenido principal
Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement
Qué necesitas
  1. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: paso 1, imagen 1 de 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: paso 1, imagen 2 de 2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 2, imagen 1 de 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 3, imagen 1 de 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 3, imagen 2 de 2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 4, imagen 1 de 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 4, imagen 2 de 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 4, imagen 3 de 3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 5, imagen 1 de 2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 5, imagen 2 de 2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 6, imagen 1 de 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 6, imagen 2 de 3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 6, imagen 3 de 3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard and trackpad panel away from the device.
Conclusión
4 personas más completaron esta guía.
Alex Cass
Miembro Desde 04/26/17
285 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S21-G2, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 2,219
