Saltar al contenido principal
Lenovo Ideapad Yoga 2 11 Battery Replacement
Qué necesitas
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 2, imagen 2 de 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 3, imagen 1 de 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: paso 4, imagen 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 5, imagen 1 de 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 5, imagen 2 de 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 6, imagen 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 6, imagen 2 de 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 7, imagen 1 de 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: paso 7, imagen 2 de 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
Conclusión
2 personas más completaron esta guía.
Andria Chen
Miembro Desde 10/17/17
624 Reputación
5 Guías creadas
Equipo
Un comentario
Excellent instructions makes it easy even for novice
bhimanagouda patil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,815
