Introducción
This guide will show the necessary steps to be taken to replace the hard drive in a Lenovo Ideapad 320-15IAP. The hard drive may need replacement if you experience frequent crashes or hangups while accessing the computer’s memory, the computer has difficulty starting up, or if you notice corrupt files in repeated occasions. You may also want to upgrade your hard drive to a 2.5” solid state drive to increase your computer’s speed, which can also be accomplished using this guide.
Qué necesitas
Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
2 personas más completaron esta guía.
