Saltar al contenido principal
Lenovo IdeaPad G50-45 Screen Replacement
Qué necesitas
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: paso 2, imagen 1 de 1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad G50-45 Screen Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad G50-45 Screen Replacement: paso 3, imagen 3 de 3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: paso 4, imagen 1 de 1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: paso 5, imagen 1 de 1
    • Test the new screen by turning it on before putting the bezel back on.
Conclusión
6 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Miembro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Miembros
5 Guías creadas
2 comentarios
The tutorial was pretty straightforward, and worked.
Remy G - Contestar
My Laptop is got work the searen is blue it what trun on
Rebecca - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 7,867
