Saltar al contenido principal
Lenovo IdeaPad Flex 5-1470 Speaker Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 4, imagen 2 de 2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
Conclusión
Ryan Beste
Miembro Desde 01/23/20
141 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S2-G5, White Winter 2020 Miembro de Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 1,134
